as long as it is in a position where it is clearly visible i guess they wont say anything. i rekon if u have it on the bottom lip where it is facing upward instead of forward than they will most probably have something to say about it
Must meet the following, as per the June 2006 revisions:
- Any part of the number plate is not more than 1300mm from the ground;
- The number plates are substantially parallel to the vehicle's axles;
- Any number plate is not obscured, for example by a towing attachment, gooseneck or tow ball;
- Any number plate cover is not tinted, reflective, rounded or bubble like;
- Any number plate is of RTA issue, is damaged or faded to the extent that the registration number is not visible;
- Characters on the number plate are clearly visible from a distance of 20 metres at any point within an arc of 45 degrees from the surface of the number plate above or to either side of the vehicle.
so side mounts are legal if they can be viewed at 45degrees, sweet
what does that mean exactly? they cant be on some massive angle?
and YES SIDE MOUNTS ARE LEGAL... how many times do you see Alfa Romeos with them? all the new ones do due to the grill...
thats my 2c anyway...
everyone can see how alfa's have the plate there but are you going to sit there arguing that fact to the next cop that says something?
no, im going to shut the f**k up and say 'yes officer' like everyone should, then comply the plates to the RTA's laws, not Mr Policemans laws... as they are the governing body over the roads and vehicles...
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
