my birthdays comming up and i got a relative spending about 200 on me. so i defenitly wanna get something for the line. so far ive allready got front dump, boost controller, full exhaust, heavy duty clutch, and KnN filter. will also be getting a fmic in a couple of weeks. so my question is what should ii get next (as far as performance) for around that price range.???????
one option i was considering getting a tune on a dyno.
any other suggestions??
https://www.sau.com.au/forums/topic/159235-200-bones/
Why does everyone always think about power mods?
You can get just about ANY suspension component (within reason) for around the $200 mark.
Tie Rods, Rack Ends, Caster Arms, Camber Arms, Hicas Lock Bar etc.
Someone mentioned tyres, thats also not a bad option... for $200 your pretty limited, id be looking at something for your suspension. Grab them for your bday, set them aside, accumulate a few more parts, throw it all in one weekend and get yourself a wheel alignment.
EDIT:
Add some nice brake pads or a service to that list as other options also.
Edited by `nigno
https://www.sau.com.au/forums/topic/159235-200-bones/#findComment-2955895
cos this is SAU. that and there arnt any real good suspension mods u could get for that. caster, camber etc bushes all need a wheel alignment, so ur looking at another 100 or so ontop. for suspension its probs best to save up for all them at once so u can get the wheel alignment at the same time.
only thing really is maybe sway bars, or i should say; bar.
https://www.sau.com.au/forums/topic/159235-200-bones/#findComment-2957246
    • Finally addressing my catch can and oil setup Plan is to do as much as practical without having to remove the motor or pull it apart. (no back of head to sump drain/breather or oil restrictors) First step is a set of full length baffle plates from Hypertune and a Tomei cam cap stud kit. I could probably have laser cut and bent up my own ones but this took any guess work out
    • I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
    • Does anyone find that they have to tighten their alternator belt once in a while? Mine started squealing again.
    • I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable.  Does anybody here have one? They're fairly cheap (~$3k) considering...  https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
    • Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
