Hi everyone:
Im selling off my r32 as ive just lost my job so need to repay off some debt and trade down to something smaller/cheaper
here are some details:
Car: 92 gts-t type-m (m-spec or which ever it is)
km's: just ticked over 150,000
colour: burgundy/wine red
transmission: 5spd man
All work on the car was previously done by chasers
*The old rb20 turbo has been swapped for a high-flowed rb25 and runs on 10psi
*rb25 afm
* 3' exhaust with catco high flow cat
* dyno tuned SAFC2 and rechipped ecu done by dr drift
* bosch 040 fuel pump
* exedy h/d clutch with about 5000kms on it
* kn pod filter
* car is lowered with hks rear suspension and ohlins stuff on the front
* viper alarm and keyless entry
* apexi pen T/timer
* black rims (stock front and wider gtr rims on the back)
*interior complete as is the boot both of which are in excellent condition
*clarion h/u, speakers and jaycar amp
*boost gauge (woot!)
oil is changed religiously every 5000kms
car is in excellent condition, except for the front bar which has a few cracks
the rear wing has been deleted prefessionally and rear end given a lick of fresh paint. the paint is in excellent condition
mechanically the car has no issues, blows no smoke and loses/uses no oil
I want around $9500 as i NEED the $$$, but am WILLING TO GO SLIGHTLY LOWER FOR A FAST SALE
should also add it has 11months rego and can organise a rwc
feel free to ask any questions
more pics available
im located in Mont Albert (eastern suburbia of melb)
Edited by colbs
https://www.sau.com.au/forums/topic/159262-melb-r32-gts-t/
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
