selling my car to someone now as a project as some bastards stole some of my parts,
the missing parts are rims, front bar, side skirts, front mount cooler tank only. The remaining
parts are listed below.
1996 r33 gts_t series 2
mods:
106000KMS
HKS GT-RS turbo kit
HKS superdragger 3 1/2 exhaust
HKS fully adjustable suspension
Cusco strut bars front and rear
HKS pod filter
Walbro fuel pump
Giken exhaust cam gear
Hks style split dump
Hks style stainless steel manifold
Splitfire coil packs
High flow cat
New Exedy button clutch (can handle 300kw)
Nismo 550cc injectors
Trial rear bar
Ganador side mirrors
GTR rear spoiler
im sure im forgeting something else
im looking for around 10k
ph 0412 903 309
or email [email protected]
thanks ben
https://www.sau.com.au/forums/topic/159304-r33-series-2-project-car-for-sale/
here are some pix before the parts where stolen, so just imagine it with out the front bar, side skirts and front mount. they also took my power fc and boost controller, but i still have the stock ecu to chuck back in.
i have speakers but no head unit, i think for the price i wont be putting a head unit back in. oh and im located in brisbane.
thanks ben
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
