Ok..
Even though i can see it from 2 different points of view.. I will try and obide by the unwritten rules of the forums... this will be my main post for my car and its progress.. if it is updated.. (duh) the time date will be updated)
I will link a few posts that i have done already and the rest will be in here.
Ok here is the car pretty stock.. All i had done at that stage was get the tinting done + remove some dicky strips that were on the car.. ( yes the tinting is legal.. its just a kick ass grade that looks darker then what it is)
actually.. heres a pic of it without tinting and the strip of doom. (see attached)
07/02/07
Tinting + Clean up
http://www.skylinesaustralia.com/forums/in...howtopic=156878
17/02/07
After that i started on the performance a little.. I took the car to all star on the dyno day and got a very modest 123kw of power on stock boost.. it was a good number to start on.
21/02/07
I went out and bought a Apexi Power intake (from slidewise) that week and installed that badboy.. i noticed straight away that there was a little more juice under the hood.
After that i was tossing and turning on what to do next.. but since Aussieland is hotter then Japan i thought that a FMIC was a good option..
02/03/07
I got one of the JustJap FMIC's off the forums here and got mark to give me a hand "bolting" it on.
Was a 4 hour job but in the end i was happy with the work and was also happy i was getting my hands dirty by helping on the install..again mark... thanks :)
http://www.skylinesaustralia.com/forums/in...howtopic=158803 << Front mount install topic
We kept the front bumper on there and did not cut the whole out in the middle.. so at this stage my car looks dead stock.. but when it winds up it dont.
So at this stage due to the FMIC i now have a 9psi boost
Also i used the how-to topic for maxing the boost on the stock solenoid ( as in to keep it a constant 7psi by permanent grouding of the ground wire).
05/03/07
Last night my handbrake boot gaiter arrived.. and i must say i am very happy with the quality... Noel have a look at it @ Cactus jacks as i know you were after one... put that on in 2 minutes.. didnt think a how-to post was needed for that as we already have some fantastic ones on the forums on how to remove the inside panels.
19/11/07
Finially put an exhaust on it, got a Rob Bliss one installed, got it from a fellow forum goer, Basicly it is the full system bar changing the turbo mani.
3" with a high flow cat.
Ill put it on the dyno again soon, id expect a few more bikkies for my dollar now.
http://www.fuzion-networks.com.au/images/ex1.jpg
http://www.fuzion-networks.com.au/images/ex2.jpg
http://www.fuzion-networks.com.au/images/ex3.jpg
Thats where the car is up to at this stage.. once i get more things to it.. i will update it :laugh:
Modifications
Interior
Respray of dash panel -
Refabrication of leather handbrake boot gaiter delivered
Respray & clean of nissan Mats
Exterior
Tinting -
Removing of stupid "racing strip" & Skyline sticker & "option 2" sticker on the car - Free
Performance
APexi Power Intake -
Constant Grounding of boost solenoid
JJ Front Mount Intercooler
NGK Irredium Spark Plugs -( bah should of checked the forums first.. sorry slide)
Rob Bliss Turbo Back 3" Exhaust -
Looking good. I just got a apexi pod from slide last week. Best price world wide.
Id agree with you about getting a exhaust next.
Also look at getting a turbotech manual boost control, even when set to stock boost i found it starts boosting slightly earlier.
Dean
Dean
Hi Dean
Yeah because the boost would go around 11-12psi and i only want 10 when i get the exhaust i am going to get an EBC..
And yeah..ill plug slidewise where i can.. pretty damn cheap prices they got there :)
  • 7 months later...
    • And at over $2 per litre I'm starting to consider setting up a corn mash still and converting over to alcohol and running mine on it !  Up side of that is it all doesn't have to go into the car ! Win win !
    • H2 (for cars) will never happen. It's not reasonable for any number of reasons. It's also not reasonable for almost all of the industrial uses that the fanbois say that it will be used for, again for a large number of reasons. There are some cases where it will be good. But, even those will be massively hampered by the economics. The only way that H2 can be economic is if we somehow manage to get from where we are to the other side of the economic-valley-of-death in which no-one can operate. You need there to be sufficient renewable generated electricity to be available so that it is effectively free. Once you are there, you can do whatever the hell you want and hang the efficiency. But until you get there, the ever diminishing value of electricity makes it harder and harder to encourage businesses to build the new generation capacity, and they will simply stop investing in generation projects. (I kinda think there needs to be just government money spent on building the required capacity in a non-commercial way, similar to how the first fossil fueled grids were built, as national-government owned utilities. And probably some nuclear in there to start. But this all should have started 10-15 years ago to avoid the chasm of death that we face right now). Synth fuels will be much more likely, but will only occur is there is at least some renewable H2 production, because you need H2 to do it. And you need stacks of free (or at least extraordinarily cheap) energy because assembling molecules back into fuels is exactly the opposite process to burning the fuel, and the reason we burn fuels is because there is so much energy squeezed into each molecule. So you're somewhat subject to the same economic valley of death problem as above anyway. That is unless people are willing to pay the current equivalent of $5 or $6 per litre of petrol-ish liquid fuels. Can you imagine it? The squealing at $2 now is bad enough.
    • This is so cool. Get a dashcam that records audio and hopefully you'll catch it.  Maybe there's a brand or some kind of markings on the back ? Are the pics hand drawn? I love it so much.
    • Hahaha yep, point(s) taken. I just like seeing different things and an EV in an R32 is pretty different. I'm not on the EV band wagon, I'm waiting for synthetic fuels or hydrogen personally.
