I have now been tuning ECU’s for about 2 years and have had excellent results. I have tuned everything from completely stock cars to highly modified with larger injectors, turbos, AFM and even methanol injection. I have currently have the equipment to tune R32, Cefiro, Silvia, 180SX, Laurel, 300ZX and a few others. I can not tune R33 skylines due to the chip used.
I have all the equipment and have the ability to do map tracing and socketing ecu’s. All you have to do is pay for the dyno time and a bit to cover my costs.
You would have to allow for 2 hours dyno time and $50 for my efforts and cost of chips, sockets, travel, and time. Normally people would charge a minimum of $350 for this service.
You will get a new fuel and timing map to suit your mods, speed limiter and rev limit set to whatever you want, mass AFM sensing will be removed so no more “boost cut” and all will be checked on the dyno. You will have better power delivery and in most cases improved economy and heaps more power.
What I will want in return is a before and after printout of the dyno runs to show the performance gain achieved. Mainly so I can have some testimony from customers. That’s all I ask
Below is a couple of graphs of cars tuned by me.
R32 skyline RB20DET Slide hiflow, Stock injectors, RB20AFM, GTR fuel pump 14psi.
R32 skyline RB20DET Slide hiflow, GTR injectors, RB20AFM, GTR pump 18psi.
If you are interested please PM me.
Thanks!
I am unable to do R33's due to the type of ROM they use. the chips are $100 each and you can only write to them once :0 so each retune needs a new chip. and I don't have a suitable programmer :)
With R32 skylines and other nissan ECU's they used an EPROM that can be erased and reused.
Cheers!
Hey Nic,
I will most likely be interested in this after I get my GTR changed to Canberra Rego, had abit of delay the last couple of weekends due to the rain. I think my car was running pretty rich hence the dirty bumper that you usually see when I drive the R32 to work.
Michael
  cambo200sx said:
hey mate can you remap s14 series 2 ? Also have much roughly when every thing is done ?
Hi Cambo. Yes it can be done but it gets expensive very quickly
With The S14 there are 2 different types of ECU. 1 can be tuned and the other not. You need to fit a daughter board with 2 eproms. the daughter board is $100 eproms a few $$$ and than tuning. all up including dyno time you would be looking at between$600 and that is if your ECU is the tunable one :ninja: if not you would have to hunt around for the correct ECU and would probably pay $200 for one. by that stage you are into Power FC territory.
  yaf28f said:
Hey Nic,
Michael
really? i'd just come to accept this was the price i paid for buying a white gtr. i may be interested in that case. so i'm assuming you can still work some magic with a completely stock 32gtr?
a completly stock GTR will benifit the most from a remap :) they run ultra rich from factory 10:1 at full throttle and also have a slightyl erratic timing map.
you can gain 30rwkw with just a remap and no other changes :D you will also have better fuel economy and less black crap!
My car is the one in the 2nd pick making 238rwkw (now a bit more) and i never get any buildup on my bumper. (it is black already) but if you wipe it no soot comes off:)
count me in then. just gimme a couple weeks for some funds to come in.
edit - having never chucked a car on a dyno before how much would i be looking at for dyno use and would there be an ideal dyno in canberra to use? cuz obviously i'd rather use an accurate one!
Edited by shredder667
well it looks like my turbo has finaly bit the dust. so im looking at getting it high flowed within the next 4-5 weeks. once thats done i'll finaly get you to tune mine.
no probs ;) happy to help.
checkout sliding performance turbos :D thats what have put on mine and 240rwkw later i am really happy with it. they cost around $1000 vs $2000 for a GCG hiflow
    • Ahhh, that, yeah, but it all worked out well in the end As for the ITB noises, I don't really wind it out with her in the car, and the dort only really starts dorting hard when your WOT or up it hard
    • It wasn't about the dollars. I mean how she didn't like the loud exhaust and you had to change it again 😛
    • I'll tell her I put in a new air filter on it, which, it would have anyway with the ITB's In the end she isn't to fussed, she spends lots of money on hair, nails, make-up and all the other "required" beauty products that women use, plus I grease the wheels with shiny gifts and holidays wherever and whenever I can She once questioned my car spending "budget", but after itemising everything she spends on herself, and what I spend on her, and the fact that I don't care if she does or doesn't wear make-up and fancy pants perfume, or requires new outfits for every wedding, funeral or anything else she deems worthy, and I'm quite happy to go "real" camping, instead of staying in hotels or jaunts on cruise ships, she decided not to press the subject on how I spend funds, and has never asked "how much did that cost" again, so a win to me And how often can you say you really get a win with the fairer sex? She is a good woman, and in the big picture, I'm really lucky.....that she hasn't killed me yet
    • What will you do when the Minister of War and Finance says the intake noises are too loud?
    • Will the clear coat dissolve the ink tho?? I thought about clear vinyl tape too. Thinking what to do haha. The one I have now is cracked in 1 spot, otherwise mint. Plus the MINES one is much thicker plastic material so its not flimsy at all.
