the endless debate
R32 looks better, lighter, handles like a go kart, looks better kitted, not as many around, nicer interior IMO....
driven both and much prefer the R32,
take them for a drive and buy what you like the best, i did this when i was tossing up between 180vs r32
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2962380
  • Replies 63
Posted Images
i went the r33 for a few reasons.
1. they are a quicker car. sure they weigh a bit more, but they have more power, and a better power/weight ratio. a r32 with 2 people in it weighs about the same as a r33 with 1 person.
2. nicer interior. the are a more modern looking interior with a nicer looking dash.
3. price. its easier to find a cheap clean 33 than it is 32. a clean 32 will often cost more than a clean 33.
4. did i mention that they are quicker?
i was tossing up between a 33 and a 180sx. i had quickly ruled out r32 (unless it had a rb25 in it). i couldn't see the point of the r32. they have about the same power (7kw more power, but less torque) than a sr20 powered silvia/180sx, but weigh about 100kg more so i ruled them out.
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2962597
get a 32gtr then, hehe.....
but seriosuly....mado82 made a particular good point :
"3. price. its easier to find a cheap clean 33 than it is 32. a clean 32 will often cost more than a clean 33"
psersonally i think it comes down to visual prefrence...the 32 is still a quik car and can be made quiker very easily.
if u think the 33 is a great lookin car then why wouldnt u get a 33???
i got a 32 cause i think they have more presence and cause i love the history on the 32gtr...
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2963076
33 :P
- Newer
- Better gearbox
- Better motor
A set of coilovers & sway bar and it handles brilliantly
Exhaust, FMIC and a touch more boost and its an awesome daily driver that you can drive to and from the track with no probs at all
Then if u decide you want to go crazy, throw a rb26 in it hehe :)
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2963197
Ahh, the shallow mind of a gtst owner
GTR32 > S2 GTST33 > shit on a stick > GTST32
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2963769
people have been saying that the S2 interior is better than S1..
Funny thing is, Mine is a S1 Type M and the interior is much nicr than 2 of my mates S2's. Theres is Sort of like Canvas. and Mine is like Velvet furr. Could be a Type M thing not too sure on that.
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2965380
Im thinking of buying a R32gtr with a R33 GTR engine with massive mods in it.
Would this be a good way to go? Should i get a mechanics report and a compression test?
Mods below: (sorry i wasnt sure how to link it to the mods and i apologise if it seems like i am stealing this thread. Just advice is needed.)
Dynoed at 20psi 360rwkw, 300rwkw at 1 bar tuned by JEM, these are safe tunes as its used as a daily driver.
96,000K on clock
2.6 litre twin turbo coupe with an
R33 GTR engine and Trust 618z turbos
ENGINE AND ELECTRONICS
APEXi Power FC and FC Commander unit
HKS EBC
Forged Pistons
TOMEI 260 degree cams
TRUST adjustable cam gears
HKS 1.2mm head gasket
HKS metal gaskets for plenum and exhaust manifolds
Sard 680cc injectors
SARD fuel regulator
N1 water pump
HKS delivery pipe
Bosch intank 044 pump
Polished Plenum
Oil catch like the powerplay ones + oil Air separator
Cusco Intercooler Intake pipes with Custom Turbo Intake Pipes (aluminuim)
Custom Carbon Fibre Air Box with CAI
Cusco master cylinder brake stopper
Z32 airflow meters, new apexi pod filters
Dual core radiator with cusco air panel diverter
TRUST dual core Intercooler 75mm
TRUST oil cooler and oil filter relocator Power Enterprise magnetic oil filter used
OS Giken twin plate clutch with lighten flywheel
R33 Brembo brakes front/rear with Earls braided brake lines F/R
NISMO circuit link suspension parts
AS - front pillar brace bar, for more rigid chasis
Chasis has been Pop Riverted for extra rigidity from engine bay to front cabin
Adjustable Front Upper Arms (camber)
G4 - Height and dampner adjustable suspension
ARC adjustable castor rods
Rear HICAS cancellation bar
ARC front and rear strut tower braces
ARC front and rear sway bars
NO ABS
TRUST dump/front pipes
3n1/4 inch Kakimoto stainless steel exhaust
Hi flowed Catco cat converter
Push Start Button with kill switch
Battery relocated to the boot
RWD toggle switch made by Dirt Garage
GReddy Electronic Boost gauge and HKS oil temp gauge
4WD controller by Raceworx installed (Duncan)
Turbo timer
Trust Gear Knob
3point immoboliser with auto window lifter, works with turbo timer
Rays Engineering 17x10inch rims, chrome outter and gold innner 2 piece rims 255x40
N1 front bar with front lip on bonnet (carbon fibre)
N1 head lights
N1 lip on the boot
N1 style side skirts
Kenwood MP3 player with Clarion 6inch splits, Clarion 6inch rear speakers
http://www.skylinesaustralia.com/forums/in...sg&id=86332
Edited by jakegts
https://www.sau.com.au/forums/topic/159371-32-or-33/page/3/#findComment-2967210
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
