32 Or 33
the endless debate
R32 looks better, lighter, handles like a go kart, looks better kitted, not as many around, nicer interior IMO....
driven both and much prefer the R32,
take them for a drive and buy what you like the best, i did this when i was tossing up between 180vs r32
  • Replies 63
Posted Images
i went the r33 for a few reasons.
1. they are a quicker car. sure they weigh a bit more, but they have more power, and a better power/weight ratio. a r32 with 2 people in it weighs about the same as a r33 with 1 person.
2. nicer interior. the are a more modern looking interior with a nicer looking dash.
3. price. its easier to find a cheap clean 33 than it is 32. a clean 32 will often cost more than a clean 33.
4. did i mention that they are quicker?
i was tossing up between a 33 and a 180sx. i had quickly ruled out r32 (unless it had a rb25 in it). i couldn't see the point of the r32. they have about the same power (7kw more power, but less torque) than a sr20 powered silvia/180sx, but weigh about 100kg more so i ruled them out.
get a 32gtr then, hehe.....
but seriosuly....mado82 made a particular good point :
"3. price. its easier to find a cheap clean 33 than it is 32. a clean 32 will often cost more than a clean 33"
psersonally i think it comes down to visual prefrence...the 32 is still a quik car and can be made quiker very easily.
if u think the 33 is a great lookin car then why wouldnt u get a 33???
i got a 32 cause i think they have more presence and cause i love the history on the 32gtr...
33 :P
- Newer
- Better gearbox
- Better motor
A set of coilovers & sway bar and it handles brilliantly
Exhaust, FMIC and a touch more boost and its an awesome daily driver that you can drive to and from the track with no probs at all
Then if u decide you want to go crazy, throw a rb26 in it hehe :)
Ahh, the shallow mind of a gtst owner
GTR32 > S2 GTST33 > shit on a stick > GTST32
people have been saying that the S2 interior is better than S1..
Funny thing is, Mine is a S1 Type M and the interior is much nicr than 2 of my mates S2's. Theres is Sort of like Canvas. and Mine is like Velvet furr. Could be a Type M thing not too sure on that.
Im thinking of buying a R32gtr with a R33 GTR engine with massive mods in it.
Would this be a good way to go? Should i get a mechanics report and a compression test?
Mods below: (sorry i wasnt sure how to link it to the mods and i apologise if it seems like i am stealing this thread. Just advice is needed.)
Dynoed at 20psi 360rwkw, 300rwkw at 1 bar tuned by JEM, these are safe tunes as its used as a daily driver.
96,000K on clock
2.6 litre twin turbo coupe with an
R33 GTR engine and Trust 618z turbos
ENGINE AND ELECTRONICS
APEXi Power FC and FC Commander unit
HKS EBC
Forged Pistons
TOMEI 260 degree cams
TRUST adjustable cam gears
HKS 1.2mm head gasket
HKS metal gaskets for plenum and exhaust manifolds
Sard 680cc injectors
SARD fuel regulator
N1 water pump
HKS delivery pipe
Bosch intank 044 pump
Polished Plenum
Oil catch like the powerplay ones + oil Air separator
Cusco Intercooler Intake pipes with Custom Turbo Intake Pipes (aluminuim)
Custom Carbon Fibre Air Box with CAI
Cusco master cylinder brake stopper
Z32 airflow meters, new apexi pod filters
Dual core radiator with cusco air panel diverter
TRUST dual core Intercooler 75mm
TRUST oil cooler and oil filter relocator Power Enterprise magnetic oil filter used
OS Giken twin plate clutch with lighten flywheel
R33 Brembo brakes front/rear with Earls braided brake lines F/R
NISMO circuit link suspension parts
AS - front pillar brace bar, for more rigid chasis
Chasis has been Pop Riverted for extra rigidity from engine bay to front cabin
Adjustable Front Upper Arms (camber)
G4 - Height and dampner adjustable suspension
ARC adjustable castor rods
Rear HICAS cancellation bar
ARC front and rear strut tower braces
ARC front and rear sway bars
NO ABS
TRUST dump/front pipes
3n1/4 inch Kakimoto stainless steel exhaust
Hi flowed Catco cat converter
Push Start Button with kill switch
Battery relocated to the boot
RWD toggle switch made by Dirt Garage
GReddy Electronic Boost gauge and HKS oil temp gauge
4WD controller by Raceworx installed (Duncan)
Turbo timer
Trust Gear Knob
3point immoboliser with auto window lifter, works with turbo timer
Rays Engineering 17x10inch rims, chrome outter and gold innner 2 piece rims 255x40
N1 front bar with front lip on bonnet (carbon fibre)
N1 head lights
N1 lip on the boot
N1 style side skirts
Kenwood MP3 player with Clarion 6inch splits, Clarion 6inch rear speakers
http://www.skylinesaustralia.com/forums/in...sg&id=86332
Edited by jakegts
 Share
    • You all are absolute legends! Thank you for helping me put this into context with your comparisons!
    • There's probably an underlying issue with the A/C system too. I recently fixed mine, now it's fully control by the Haltech and car's factory HVAC controller  Have a squiz here:
    • And by the way, I've also checked the ECU diagnostic numerous times and got a bad O2 sensor code and initially an Ignition Primary code, which is why I replaced the O2 sensor and all the ignition components (coil packa, plug and loom). No codes have been coming up lately despite the ongoing issue.
    • Hey pber13, unfortunately still no luck. At this point the following has been done with little or no success: - Spark plugs replaced, gapped to 0.8mm - Splitfire coilpacks installed to replace originals - Replaced Ignition Coil/Coilpack harness with a new genuine nissan one - New fuel filter - Replaced AFM/MAF sensor - Injectors have been thoroughly cleaned with an online flush (without removing) - Upper engine and inlet decarbed - blew tons of black smoke out, cleared the carbon deposits from the top of the engine and exhaust.  - IACV removed and thoroughly cleaned with carburettor cleaner - O2 sensor replaced with new and genuine one -  Smoke test revealed no vacuum leaks - Healthy compression test of 160psi across all 6 cylinders Overall the car does run a lot smoother now, no backfires between gear shifts like it did originally... but the rough idle when warmed up is still there. It may not even be a misfire but simply a rough idle. Seems crazy to me that so many people have had this issue and seemingly no one has gotten to the bottom of it, or at least never bothered to post if they did! Hope you have more luck than I did pber13, I'm at a point now where I'm just going to try to ignore it unless it gets worse. Would love to fix it but I've genuinely run out of ideas of what it could be.
    • I got the full frenchys kit too. Really awesome kit. Easy to install my only complaint was the hardlines I think could be routed differently (I modified mine) but I realise the kit needs to suit multiple applications. This was the hard lines before I modified them. They were touching the wastegate pipe. I ended up reducing the distance between firewall and first bend. The made it so they tucked along the frame rail.
