  • Replies 54
Well guys after a few solid years building skylines i have a heap of gear sitting about that needs to go. All gear is in top nick, but has been sitting around between 6 months and 3 years.
So here it goes
RB25 Stuff
Complete Long Motor $2000Now $1500
Bottom end $1000Now $800
Cyl Head $1000Now $800
Z32 Air Flow Meter SOLD
RB26 Stuff
Pair of R33 GTR Turbos in great nick $500Now $400
RB26 Motor- Sub assembly consisting of crack tested, shot peened and polished block and new welsh plugs.
Crank has been shot peened and nitrided, oil gallery plugs removed and grub screws fitted.
Pistons are from Specialised Piston Services.
Conrods have been lightened, shot peened and polished, fitted with Jun rod bolts.
All components have been fully balanced.
travelled 4,000k's $4000Now $3500
RB26 Sump (no diff) $200Now $150
R32 Bilstein Shocks & Springs $600Now $500
New heavy duty Valve Springs $300Now $250
R33 RB26 Crank $600Now $500
Blank RB26 Head, Pro Ported (needs guides) $500Now $450
Pair of M's Pods and elbows to fit them. $200Now $150
Also have a L/H tail light from an r33, indicator is slightly cracked (black) $50
I'm sure i'll find more as i go, but this should at least clear up some room so i can buy some more stuff lol!!!
If interested post here or send me a PM.
Cheers
Ben
post-3771-1173177645.jpgpost-3771-1173177690.jpgpost-3771-1173177740.jpgpost-3771-1173177782.jpgpost-3771-1173177819.jpgpost-2023-1130059116.jpgpost-3771-1173177897.jpgpost-3771-1173177976.jpg[attachmen
=86395:attachment]post-3771-1173178092.jpgpost-3771-1173178146.jpg[att
chment=88288:pods.jpg]
hi im interested in rb26 motor i would like to buy it ,if you can please cal me on 0422624559
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
