  • Replies 54
Well guys after a few solid years building skylines i have a heap of gear sitting about that needs to go. All gear is in top nick, but has been sitting around between 6 months and 3 years.
So here it goes
RB25 Stuff
Complete Long Motor $2000Now $1500
Bottom end $1000Now $800
Cyl Head $1000Now $800
Z32 Air Flow Meter SOLD
RB26 Stuff
Pair of R33 GTR Turbos in great nick $500Now $400
RB26 Motor- Sub assembly consisting of crack tested, shot peened and polished block and new welsh plugs.
Crank has been shot peened and nitrided, oil gallery plugs removed and grub screws fitted.
Pistons are from Specialised Piston Services.
Conrods have been lightened, shot peened and polished, fitted with Jun rod bolts.
All components have been fully balanced.
travelled 4,000k's $4000Now $3500
RB26 Sump (no diff) $200Now $150
R32 Bilstein Shocks & Springs $600Now $500
New heavy duty Valve Springs $300Now $250
R33 RB26 Crank $600Now $500
Blank RB26 Head, Pro Ported (needs guides) $500Now $450
Pair of M's Pods and elbows to fit them. $200Now $150
Also have a L/H tail light from an r33, indicator is slightly cracked (black) $50
I'm sure i'll find more as i go, but this should at least clear up some room so i can buy some more stuff lol!!!
If interested post here or send me a PM.
Cheers
Ben
post-3771-1173177645.jpgpost-3771-1173177690.jpgpost-3771-1173177740.jpgpost-3771-1173177782.jpgpost-3771-1173177819.jpgpost-2023-1130059116.jpgpost-3771-1173177897.jpgpost-3771-1173177976.jpg[attachmen
=86395:attachment]post-3771-1173178092.jpgpost-3771-1173178146.jpg[att
chment=88288:pods.jpg]
hi im interested in rb26 motor i would like to buy it ,if you can please cal me on 0422624559
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
