Found the ideal Multimedia solution for all you computer enthusiasts the ultimate car pc everything you can do on your home pc you can do in your car including navigation and mobile phone connectivity and much more and it is especially designed for the automotive sector, no more stuffing around with power supplies and system crashes.
https://www.sau.com.au/forums/topic/159416-car-computers/
Care to share what it is?
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2959990
http://www.bitdistribution.com.au/?stg=49
this is a site when i was flicking through a mates 4x4 magazine.
i have also seen an e-bay auction selling something similar.
it's something i'd be interested in one day as I already have a 7" screen.
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2961643
my mate did it in his commonwhore a few years back...
personally, i feel there are somethings that just shouldnt be in cars... how long do you sit in the car doing nothing if you have a computer in it???
im against them... they are a good idea and all that, but i just dont like em... i have enough shit like that in the car already...
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2963286
So what is it Dan....?
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2968182
I know Randy i've seen most of them and tried them, but this is the "ultimate" car pc. I haven't found a faults or bugs yet and it does everything including engine management system fuel pressure, manifold pressure, rpm, timing etc it can even clear some errors in the vehicle own computer that you would normally have to go to an authorised repairer to fix such as ABS light problem and AIR BAG problems.
I suppose time will tell on this products' durability and reliability so we'll just have to wait and see. :ninja:
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2968706
I suppose time will tell on this products' durability and reliability so we'll just have to wait and see. ;)
Ah ok! Nice one!
What kind of pricing can we expect?
(btw, got my alarm fitted through you/security in motion... still very happy!)
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-2969638
It inst too difficult to build your own car pc. All you need to to buy a 12v PSU to replace the 240V ATX unit in the standard case (and find somewhere good to hide/mount it). That way you can have a powerful computer, not just some piece of crap integrated graphics chipset ULV computer.
https://www.sau.com.au/forums/topic/159416-car-computers/#findComment-3004279
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
