if you have the stock pipework and filters or airbox still
then look at the nismo's afms
they are same size 65mm so you dont have to change anything and give the resolution of the z32s. basically its a z32 chipset inside a GTR 65mm shell. moving to z32s requires 80mm pipework and pod adapters to suit, so it can be over 1000 if buying new afms and pods, kit, adapters and pipework
check out the nismo 65mm's option
hey all jsut keep getting told diffrent things buy diffrent shops. some tell me to run twin z32 afm's and some tell me to jsut run 1 q45, this is on a rb26 single turbo conversion.
can some1 or a few ppl plz tell me wat is better to do
thanks ben
Simple, one turbo = one AFM
Just parrallel up the wiring from the one AFM so the PFC gets 2 signals.
The only reason you would go for 2 x Z32 AFM's is if your power target exceeds the capacity of one Q45 AFM. That's around 650 bhp, but it does vary from car to car.
:P cheers :O
I heard somewhere.. that the reason some workshops suggest 2 X Z32 AFM's is because the Z32 afm has a broader band sensor inside.. and thus has higher mapping areas.. Where as the Q45. although bigger the Sensor inside is not as broad ranged.. and is limited in the way of fine tuning..
Don't flame.. its just what i've heard - Please correct me?
Cheers
Edited by R32-PSH77
