I am selling my 1995 R33 GTR Huge list of modifications to all areas. Here is what I can remember. Vehicle shows 36XXX KM but unlikely to be original KM. I got car with 34 xxx Km and have put a lot time and $$$ into modifiying it for performance and reliability.
Vehicle comes with rego till december and RWC supplied.
Engine Re-built approx 2500 KM ago by Race Pace with:
-Forged Pistons (Arias)
-Metal head gasket
-N1 Oil pump
-N1 or ACL bearings
-New crank
-Head Work (I believe just general tidy up)
-New belts
-Engine Blue Printed
At same time had New plates fitted to Twin PLate clutch.
Vehicle also has R34 N1 Turbo's (approx 6000KM)
Bosch Fuel pump
550 Injectors
Nismo AFM
Larger FMIC
HKS Adj Cam Gears with clear cover (std cams only)
HKS pod filters
Exhaust has split dumps into Race pipe through Cat into 2 3/4 in Exhaust. All fitted by Dean at UPI.
Vehicle tuned with PFC and Blitz Dual SBC (EBC) Originally tuned by ben at Race pace and Last on Dyno at Racingline and put out 301 RWKW @ 20 psi
Has standard R33 GTR Brembro Brakes. Upgraded suspension with King Springs, sway bars and upgraded castor arms. 18 x 10 Zagtar mags with Falken 265/35Z R18 tyres.
Vehicle has been re-sprayed metallic black as originally chamellion paint job when I purchased it. GT spoiler fitted and dark tinted windows. Has re-mote central locking with alarm and 3 point Immobiliser. Turbo timer also fitted linked in with alarm.
Sterio has also being upgraded to include JVC head unit, 6 1/2in splits front and 6 in splits in rear with parcel shelf strengthened. 2x10 in Kicker comp subs in box in boot with Kicker amp and PWM V12 4 channel amp running speakers.
Interior standard seats in excellent condition and has MOMO steering wheel and Razo gear knob.
All work done by only the best work shops in Vic with Race Pace, Racingline and UPI only ones worked on car. Vehicle has been modified tastefully for overall performance, handling, looks, sterio and most importantly reliability. Receipts available for most work/parts.
Reason for selling need money to work on house.
Price $35,000
Visit My Website
Pic added soon
https://www.sau.com.au/forums/topic/159437-sold/
  • 4 weeks later...
  • 4 weeks later...
  • 2 months later...
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
