There seems to be a bit of discusion on afm pulse vs intake length, in regards to idle hunt rough idle and the likes, I would like to open a discussion on, the best intake length to overcome or to minimize the issues that are related to afm pulse being the afm too close to the inlet of the turbo. Recommendations of peoples experiences in this case as well, what is the best length from turbo inlet to the afm in regards to custom intake pipes.
As this may be a very common problem that i have seen and or experienced lately. All comments welcome
Cheers A
https://www.sau.com.au/forums/topic/159495-afm-pulse/
Call me crazy, but does'nt the afm also measure the air temp? and so putting it in post turbo could affect tuning - I dont know, just a thought.
AFM's basically inform the ECU of the amount of charge required to keep the hot wire at a certain temp. Thus more air running over the hot wire = more charge to keep the stable temp.
Therefore if the air is pressurised & heated it may well effect the AFM's readings.
It all comes down to the cooling properties of pressuries air verses un-pressurised air.
Not sure if any of that makes sense :(
Sorry, getting off topic here...
https://www.sau.com.au/forums/topic/159495-afm-pulse/#findComment-2963755
Cheers A
I take it you are looking for discussion on poor idle (and return to idle) due to airflow reversion back though the AFM from the compressor of a large turbocharger. If that’s the case, then it has been covered many times. For a detail discussion try a search on “reversion” and perhaps “EIDS” which is the HKS electronic circuit for overcoming such problems.
In simple terms, use the largest inlet pipework you can, put as much distance between the compressor inlet and the AFM as possible. If all else fails grab an EIDS or relocate the AFM to the pipework on the compressor outlet, before or after the intercooler. Then retune the engine with those items in place.
:D cheers :D
https://www.sau.com.au/forums/topic/159495-afm-pulse/#findComment-2964322
Your crazy!
Jokes
Bout the temp thing. I too initially thought it would be an issue, though the stock setup does fine on both a 40 degree day / 3 degree day. Although i haven't yet taken steps to stick the AFM in the IC piping, i would rather that way, then trying to make distance between AFM and turbo mouth.
https://www.sau.com.au/forums/topic/159495-afm-pulse/#findComment-2964727
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
