narb77 Posted March 7, 2007 Share Posted March 7, 2007 Hi, my rb20det is on its way out and iv bin readin up on a rb25det conversions and decided to go ahead with the transplant. Just would like some advice on what of my aftermarket rb20 parts i can reuse because they are still in good condition List of what i have: High mount manifold Garret GT3076R Externall gate Power Fc with controller (AP Engineering, would realy like to keep this if i can) Sard injectors (think they are 550) 600hp fuil pump Hybrid cooler(piping should be identical) Remote oil Cooler. Bassically just all the bolt on stuff. Decided just to upgrade engine instead of putting internalls into this one. Also the only bit about transplant im usure about is fitting the RB25 gearbox in. Its an R32 gtst. Would all mounts line up. Any information about where i might get an r33 half cut from, with engine and gearbox in good condition would be handy as well. Near Brissy area would be best. Thanks Fellas Mike. Link to comment https://www.sau.com.au/forums/topic/159500-aftermarket-rb20det-parts-rb25det/ Share on other sites More sharing options...
Adriano Posted March 7, 2007 Share Posted March 7, 2007 Everything except the pfc and sard's will bolt straight on, you could either sell the pfc and buy an rb25 one(with money in your pocket)or make it fit which wont be hard, just use your existing look and sensors. The injectors should be able to be made to fit, just need an aftermarket rail, or maybe mod you rb20 one. Link to comment https://www.sau.com.au/forums/topic/159500-aftermarket-rb20det-parts-rb25det/#findComment-2961628 Share on other sites More sharing options...
narb77 Posted March 7, 2007 Author Share Posted March 7, 2007 yeh thought that was the case, just wanted to make sure. thanks for that. Link to comment https://www.sau.com.au/forums/topic/159500-aftermarket-rb20det-parts-rb25det/#findComment-2962478 Share on other sites More sharing options...
WazR32GTSt Posted March 7, 2007 Share Posted March 7, 2007 hmm as far as the ECU goes, what about if you keep the rb20 sensors and use them on the rb25 engine? then you can keep the powerFC and still have your rb25 running right? Link to comment https://www.sau.com.au/forums/topic/159500-aftermarket-rb20det-parts-rb25det/#findComment-2962663 Share on other sites More sharing options...
ChrisDriver Posted March 8, 2007 Share Posted March 8, 2007 Hello how ya doing if you do decide to sell i would be up for buying that Power FC off ya Link to comment https://www.sau.com.au/forums/topic/159500-aftermarket-rb20det-parts-rb25det/#findComment-2965646 Share on other sites More sharing options...
