1680 from sliding performace
Not Australian Spec. Im sure if you check his part numbers youll see. Also i think they come with pillow ball upper mounts? If so, get ready to continue to spend money as on a street car, they wont last too long (6 months, Maybe 12?).
Split second have them for around $1450, similar price from J-shop
what's this pillow ball mounts dont last 12 months on a street car - you have either used defective (poor quality) parts, or have no idea what you are talking about.
I have pillow ball everything (that can be pillowballed) and my car gets thrashed hard on the track, including some decent offs, and the only time a pillow ball part hasnt lasted (ie, 6 to 12 months only) is when I bought cheap china garbage. Oh, and my car is daily driven.
pillow balls wont last as long as rubber mounts, but rubber mounts are designed for comfort, not performance - and should last years on a street driven car - they have on mine.
Some items are not worth the hassle of getting Ex Japan, buy from WA Suspensions or X-Speed because if some thing goes wrong that is when you regret buying off the Net.
Are you fitting yourself if not get the price fitted.
Not sure if that question is ment for me.
But..........
Yes i am fitting the coil-overs and EDFC myself, I also work for a scale company so i'll be corner weighing the car and adjusting to suit. :D. Once completed, i'll be taking it to Centreline Suspension for a complete alignment.
Fulcrum Susupension: 1300 suspension (1300 7877367466)
Super Street: $1772 + $20p&h (from QLD to VIC)
EDFC: $620
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
