  • Replies 194
Im not liking this weather.
Oh and Andrew. Cheers for letting us know you can't make it. It's a shame you can't come but tis how life turns out for us all.
My cars missing again and its annoying my like bugery.
Im dumbfounded on what it is.
As long as I don't boost it i am fine.
I will be at Etsa at 10:30am
If anyone wants to call me or find out extra info my mobile is 0439455399.
I have no prob with ppl calling or msging me tomoz or sunday morning.
If i dont reply for a while im working tomoz from 4:30am to 12:30pm tomoz. Then off to a workshop to fix my dam car.
40 maps printed so far.
Brenton
it doesn't take all weekend to install a turbo...
install sat, fiddle around and finish sun morning then boost sunday arvo!
yeah but the big issue it won't be tuned - hardly good to take it 250km of thrashing with an untuned turbo ....
but it is not just turbo - try turbo, radiator, oil cooler, trans cooler, radiator breather, oil breather, fuel pump, fuel pressure regulator - and various other bits and pieces :kiss:
well im screwed........no permit, they wont let me have one i am extremely p1ssed off with this fact
can anyone perhaps lend me a trade plate??????
pm me or contact me on 0404873163 to let me know.........otherwise im gonna need a lift LOL
who wants a hitcher
Andrew,
There's no thrashing on the cruise. I can't so lol no one else will be.
G1. hit up Telly. Maybe he can lend it if u bring Gumnut.
I will be playing bush mechanic tomoz so hopefully all goes well.
Good to hear about the weather guys.
Very Excited.
Andrew,
Very Excited.
what are you fixing tomorrow?
making a new clutch out of a tree?
holding the diff in with some barbed wire?
replacing your brake pads with cuttle fish?
or are you just braking out the zip ties?
lol All of the above.
gotta put da tree up under the steering rack to slide around on the dirt brudda.
Nah fix this bloody misfire. I cant for the hell of me figure out why its only missing when i flatting it to the floor. If i put it down gently it wont miss.
Andrew,
Very Excited.
we will get to do a bit of 'spirited' driving though the hills though won't we?
I was pulled over by a defect station they had out the front of Marion some time ago.
He pulled me over due to tint.. So.. I grabbed a corner and ripped it off.. No more tint unable to defect. :laugh:
Everything else looks and basically is stock.
lol well it didn't really go like that.
He said your tint is too dark and will earn you a defect. I said I can rip it off right now. He said " well if you can........."
I didn't say it in a smart arse manner, doing so would have got me know where.. well maybe some where 'regency'.
But saying that fingers crossed it would have earned me only a trip to the local cop shop as its not registered 40km/s out of the CBD for no reason. :laugh:
Paul.. Who's HPA with regards to your HPA FMIC?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
