i previously ran a GFB bleed valve @ 11psi. car ran fine etc... i recently installed a TURBOTECH boost controller... now i installed it and tried adjusting my boost and the car keeps dumping boost when you put your foot down around 4000 + rpm... iv adjusted it over 30 times - and i have drilled a biger hole(now 1.5mm) in the previouse hole in it like people have said - because some were manufactured with and with out this hole - which can cause pressure getting stuck between the boost controller and the actuator.. so iv done that
yet i still have the same problem..
now i was talking to a friend and he sais it could be misfiring because this controller is far better than the gfb and is making stronger boost which is causing this missfiring?
?? he told me i need to gap the spark plugs , which i was told - it would fix this problem ?? he said the current setting is 0.8 and should be 0.6? .... i would of searched but i dont know what im looking for... he also mentioned something about tapping it on the concrete to get the correct size....
any help would be gladly appreciated.
https://www.sau.com.au/forums/topic/159520-boost-problems/
make sure it is connected up properly, sorry cant help u with how to because im still new to the turbo scene but yeah i had a similar problem and it wasnt installed correctly.
usually misfiring happens when your coilpacks are getting old or your running too much boost. That being said most people are running 0.8mm gap (standard is 1.1mm... which im running at with 14psi and standard coilpacks and i have no misfire so im lucky... knock on wood lol)
you tap the plug on the concrete to get the gap down and measure it with a feeler gauge.
also check the spring and ball inside the controller and see if anything suspicious is going on there
sorry cant be much more help
Edited by tek_01
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2964205
yeah i done some searching last night... there is a remedy on this apparently which i will try out this weekend...
most coil packs get hair line cracks in them , which causes the spark to escape.. most people have taped them up and it fixes the problem so its been said.. i will attempt this , this weekend , and if not i will try to gap the spark plugs.
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2964567
ka-ching! your on the money right there... (more or less) lol
tape works... good electrical tape... aroldite... umm some people even reakon painting em ?
but it works :D
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2964600
yeah im definitly going to fix this , this weekend. i was totally excited to install this new mbc.. and i am quite happy with it - the turbotech is the go!
might even try if i can find some plastic sealer , or something , and use tape.. cause the car is runing like shit.. i dont want this problem ever..
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2965071
but it works :)
yeh painting them with good quality nail polish apparently :S just clear.. not colourd haha
CJ
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2965177
Remove your coil pack cover plate and start your car in the dark and rev it up. If the coil packs are leaking you will see the blue electrics all over the coil packs. This obviously means they are leaking.
Nail polish is the go. I had it painted on a coil on a previous car and it lasted for 2 years.
Coloured or clear, doesn't matter. It's a great insulator.
I would double check the installation of your bleed valve also. Sometimes different brands connect in a different way. Read the instructions carefully to make sure it's all sweet.
https://www.sau.com.au/forums/topic/159520-boost-problems/#findComment-2965209
    • The boot notch on the GK Tech rods is different to OEM yes. You'll find a solution. They are a good rod, I have used many of them for various setups, and no they are not ' just for drift cars', they are fine as an OEM replacement. Same goes for the tie rod ends although I found they transmitted a huge amount of NVH a normal balljoint masks, making it feel like there was something loose or knocking, even though there wasn't. If you used the same pieces on each side, no reason one angle should be different to the other side. Have you checked ride heights/measured the angles? Or just visual? Your alignment will be massively out of whack yes. Up to you; it is worth taking the time to learn wheel alignments and do it yourself. I have never had better wheel alignments and I haven't taken my car to a shop for, dunno...many many years. Spend a few hundred on equipment, do alot of research via online articles, youtube vids, and "trial and error" on setups. Eg, set it with too much toe-out, toe-in, too much or little caster, drive the same stretch of awesome twisty mountain road each time, learn how they feel and how the car's handling has reacted to your changes.
    • Won鈥檛 be hard to beat them. 馃ぃ Farken sponge cakes!
    • Nah I did not will have to another time. I only installed a blitz return flow FMIC probably 1000kms ago. When I took the old piping off there was basically no oil in piping. At this stage it has to be valve stem seals. When I roll down a big hill in gear and then throttle down the bottom, I get the same puff of smoke.
    • I believe when they added coolant to cool the turbo it negated the need for turbo timers as water continues to flow even when the engine is shut off I forget the actual terminology, I'll just say the coolant "percolates" through the turbo which stops the oil cooking itself to death  Well....that's how I see it, as all the plant at work that has coolant lines to the turbo can be shut down straight away, whereas the older plant with only oil feed to the turbo you need to idle it for a few minutes
