I was wondering for those of you using aftermarket waterpumps on an rb engine if you have noticed that the hole for the 10mm bolt is sloted? I have 1 particular 1 with no name or numbers on it that has this slot and of course it started leaking. has any1 had this same problem? I would shot the bastards who made this pump. cheers
https://www.sau.com.au/forums/topic/159539-after-market-water-pumps/
Sounds like you have the GTR N1 water pump and I believe that that slot needs to be completely filled in and then a new hole redrilled in the appropriate place
Are you serious? is there any way to tell other than the slot? it has the numbers 1W05 stamped on it if that helps. ta
