hi,
im a little concerned about the power my s1 r33 skyline is making simply due to the fact ive dished out a fair bit of $$$$ only to make power noticeablity higher than someone with simple POD zorst and boost mods.
basically i got the following mods:
* 3" Xforce exhaust with high-flow cat
* JustJap FMIC
* Bosch 023 internal fuel pump (biggest piece of sh*t im gonna chuck it out)
* Bleed value (i know i should do it properly and buy an electronic boost controller)
* Splitfire coils (cost a pretty penny too)
* HKS fuel defender (does nothing for mods just stops my engine from sh*tting itself)
* NGK Iridium sparks (nothing but the best)
* APEXI POD
* Go Fast Bits BOV
car pulled 174rwkw on ~10-12psi, which i think is pretty lame for the mods and money spent. dont get me wrong the car pulls like crazy and is super smooth and reliable but reading the "Dyno Results Page" im a little concerned because there are alot of you guys making more power with half the mods.
any ideas??? i really do not want to get a new ecu or larger turbo but i just thought with the mods that i have i could be pushing the 200 mark. plus i dont like lag.
i think my next step is to run it down the 1/4, cause in the end the only numbers that matter are those.
cheers.
Edited by NicsR33
https://www.sau.com.au/forums/topic/159573-does-this-power-reading-sound-right/
I think you need a tune. My car used to run really well, but chewed A LOT of fuel. Gave it a tune and life was much better. What have you got against and aftermarket ECU? Any problems they may creep up are easily detected and solved... by the right mechanics
Edited by ctjet
humm on a stock ecu, that is ok. If you got an SAFC II or something you would see a higher figure. I picke dup 30rwks, simply by having a stock ecu and an SAFC II, as my car was super ritch.
I made 187rwKw@10.2 psi with stock ecu and SAFC II.
oh yeh i forgot about the safc. i was more concerned with pwrfc and their price tag, not to mention theres only a limited stock left. yeh my car is crunching on the fuel, it used to get 500 to a tank no problems before i got my hands on it.
i might start looking for safc retailers and get that done.
hey Nic,
What dump/front pipe you got? xforce or standard?
Is your Apexi Pod exposed or enclosed in a box/heat shield?
Like you said yourself numbers on dyno MEAN NOTHING.. just take it down to the drag strip where it counts, one of the guys with only 169rwkw has ran a few runs at 13.7 with 19" rims while others with around 200rwkw can't barely break the 14 second mark,
so see how you go GOOD LUCK! :ninja:
yeh exactly right, its all about the 1/4 mile time and im certain the way my car pulls it'll run great down there.
im pretty sure the dump is also an Xforce, but the pod is unshielded i really should fix that up.
i might look into a safc, it'll pay itself off in a few months with the money i save in fuel anyways.
yeah people on the mainland talk about getting 600 km on the higway, that would get me to Launceston and Hobart 3 times. So eaven on the highway, my ecconomy is not to great, as i always have to drive through a town. LOL.
that power figure seems about right to me
the only real power mods you have that are actually going to increase power would be exhaust and increased boost.
don't get me wrong. i wouldnt do it without a fuel pump and FMIC, etc. but you haven't put a lot of power mods in there so don't be expecting too much more
Goto agree with Waz, you don't really have any "power mods".. e.g. hi-flow turbo, new ECU, new cams, exhaust cam gear... You've just got a better flowing exhaust + a bleed valve + a pod which is arguably going to help.. 170kw is about right - that's probably 15 - 20kw more than stock..
Make the most of the rest of it with an aftermarket ECU and you should see a better result..
the two posts above mine are right on the money.
Do you really think that a BOV, crap iridium spark plugs, pod filter, colpacks and a fuel pump is going to actually increase power?
I think you need to learn more about cars before you start assuming that ANYTHING you bolt on will make it faster.... Did you expect a power increase out of your mags too?
maybe a few kw atw increase from the 19s.
nah i understand what you guys mean and come to think of it i was a bit blind to that now that i look at hte list of mods. all the other mods do is just make it run smooth, which it is and its a perfect daily driver.
im happy with the factory turbo it does an amazing job so all i can do is maximise its use with a tune. i think that might be the best way to go without spending too much extra.
cheers everyone. im still gonna run it and see what time it can do.
Why are some guys hung up on power figures? when I ran my 32 on the dyno (with minimal mods - I was just experementing with tuning the stock ecu myself) After I played around a bit I got a mighty 100kw at the wheels! I dont care, it was the fastest 100kw car I have ever driven, I could keep up with a friend in a 33gtr, and now i have even learned how to drive properly(still practicing). Pity I had to sell the car... :O
Sorry - Im bored, my last day at work and cant be bothered doing anything constructive, I should probably head off to the wasteland. Anyhow, get a tune, can make all the difference :( good luck.
just to add my bit in here. for a series 1 r33 aswell
bought the car with full turbo back kakimoto exhaust
132.2rwkw
turbotech boost controller 10psi, apexi pod in box and hks FCD
175rwkw
front mount, fuel pressure reg, 14psi
204.5rwkw
just by someone who knows what they are doing adjusting a few things like fuel pressure and the fuel cut defender after the fmic install i gained a fair bit
but yeah dont be too hung up on figures (unless your paranoid like me and think your car is shit lol)
oh yeah and 14.7 at the drags with 175kw and suspected slipping clutch
mate trust me if it were upto me the car would be at the shops with a high mount turbo, injectors and tune but im pu55y whipped and promised my gf a trip to europe.
ill look into a tune when i get bak from europe.
HOLY SHIT your in the exact situation as me... dude you will notice the difference when you get your turbo/ecu/inj....
when i get back from o/s its on like donky kong! soo can't wait :P
hey have you seen my avatar? :P
    • This is for an RB20DET. Sorry for not including that.
    • Welp, this is where my compression lands after my rebuild. Thoughts? I have ~6 hours on the motor.
    • Well, after the full circus this week (new gearbag, 14 psi actuator on, injectors and AFM upgraded, and.....turbo repair) the diagnosis on the wastegate is in. It was broken. It was broken in a really strange way. The weld that holds the lever arm onto the wastegate flapper shaft broke. Broke completely, but broke in such a way that it could go back together in the "correct" position, or it could rearrange itself somewhere else along the fracture plane and sit with the flapper not parallel to the lever. So, who knows how and when exactly what happened? No-one will ever know. Was it broken like this the first time it spat the circlip and wedged itself deep into the dump? Or was it only broken when I tried to pry it back into place? (I didn't try that hard, but who knows?). Or did it break first? Or did it break between the first and second event of wierdness? Meh. It doesn't matter now. It is welded back together. And it is now held closed by a 14 psi actuator, so...the car has been tuned with the supporting mods (and the order of operations there is that the supporting mods and dyno needed to be able to be done first before adding boost, because it was pinging on <<14 psi with the new turbo with only a 6 psi actuator). And then tuned up a bit, and with the boost controller turned off throughout that process. So it was only running WG pressure and so only hit about 15-16 psi. The turbo is still ever so slightly lazier than might be preferred - like it is still a bit on the big side for the engine. I haven't tested it on the road properly in any way - just driven it around in traffic for a half hour or so. But it is like chalk and cheese compared to what it was. Between dyno numbers and driving feedback: It makes 100 kW at 3k rpm, which is OK, could be better. That's stock 2JZ territory, or RB20 with G series 550. It actually starts building boost from 2k, which is certainly better than it did recently (with all the WG flapper bullshit). Although it's hard to remember what it was like prior to all that - it certainly seems much, much better. And that makes sense, given the WG was probably starting to blow open at anything above about 3 psi anyway (with the 6 psi actuator). It doesn't really get to "full boost" (say 16 psi) until >>4k rpm. I am hopeful that this is a feature of the lack of boost controller keeping boost pressure off the actuator, because it was turned off for the dyno and off for the drives afterward. There's more to be found here, I'm sure. It made 230 rwkW at not a lot more than 6k and held it to over 7k, so there seems to be plenty of potential to get it up to 250-260rwkW with 18 psi or so, which would be a decent effort, considering the stock sized turbo inlet pipework and AFM, and the return flow cooler. According to Tao, those things should definitely put a bit of a limit on it by that sort of number. I must stress that I have not opened the throttle 100% on the road yet - well, at least not 100% and allowed it to wind all the way up. It'll have to wait until some reasonable opportunity. I'm quite looking forward to that - it feels massively better than it has in a loooong time. It's back to its old self, plus about 20% extra powers over the best it ever did before. I'm going to get the boost controller set up to maximise spool and settle at no more than ~17 psi (for now) and then go back on the dyno to see what we can squeeze out of it. There is other interesting news too. I put together a replacement tube to fit the R35 AFM in the stock location. This is the first time the tuner has worked with one, because anyone else he has tuned for has gone from Z32 territory to aftermarket ECU. No-one has ever wanted to stay Nistuned and do what I've done. Anyway, his feedback is that the R35 AFM is super super super responsive. Tiny little changes in throttle position or load turn up immediately as a cell change on the maps. Way, way more responsive than any of the old skool AFMs. Makes it quite diffifult to tune as you have to stay right on top of that so you don't wander off the cell you wanted to tune. But it certainly seems to help with real world throttle response. That's hard to separate from all the other things that changed, but the "pedal feel" is certainly crisp.
    • I'm a bit confused by this post, so I'll address the bit I understand lol.  Use an air compressor and blow away the guide coat sanding residue. All the better if you have a moisture trap for your compressor. You'd want to do this a few times as you sand the area, you wouldn't for example sand the entire area till you think its perfect and then 'confirm' that is it by blowing away the guide coat residue.  Sand the area, blow away the guide coat residue, inspect the panel, back to sanding... rinse and repeat.
