Hi,
I own a GTST series 2 R33 and just about 2 days ago i have noticed that in second my car is missing in the higher RPM range. first, third and forth is fine just second. I had the car tuned up only about 2 months ago.
Any ideas?
Cheers
adam
Edited by Adz2332
https://www.sau.com.au/forums/topic/159575-missing-at-high-rpm-in-second/
a number of factors can effect it, bascalyl it isnt getting as stronger spark all the time thats why it misses at high rpm.
If hte plugs are old or u dont know when they wher echanged get soem NGK copepr plugs they are cheap, u can get ones that are already gapped to 0.8 , if u do a search they u can find the part code.
I remember u dont wanna buy the plus with -11 after the number becasue that indicates a 1.1ml gap.
Dodgy/old /cracked coils will also casue a miss fire.
And its normal for it to only do it in one gear? sorry bout all the questions
oi adz, take out ur spark plugs and check them, might be old/dirty or they might be new and ungapped. gap them to 0.8mm and that should do it. if u got cracks in ur coils look in the DIY section for a temporary fix, then save up for splitfires.
curently mine only does it in second after putting in plugs that i have not gapped down. So yes it can do it in certain gears as the load is different depending at what gear u in at WOT
So i guess first thing to do is remove the cover and check the coil packs. then if they look fine remove and check the gap on all the spark plugs? then gap them to 0.8? right???
:(:O
Edited by Adz2332
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
