Hi,
I own a GTST series 2 R33 and just about 2 days ago i have noticed that in second my car is missing in the higher RPM range. first, third and forth is fine just second. I had the car tuned up only about 2 months ago.
Any ideas?
Cheers
adam
Edited by Adz2332
https://www.sau.com.au/forums/topic/159575-missing-at-high-rpm-in-second/
a number of factors can effect it, bascalyl it isnt getting as stronger spark all the time thats why it misses at high rpm.
If hte plugs are old or u dont know when they wher echanged get soem NGK copepr plugs they are cheap, u can get ones that are already gapped to 0.8 , if u do a search they u can find the part code.
I remember u dont wanna buy the plus with -11 after the number becasue that indicates a 1.1ml gap.
Dodgy/old /cracked coils will also casue a miss fire.
And its normal for it to only do it in one gear? sorry bout all the questions
oi adz, take out ur spark plugs and check them, might be old/dirty or they might be new and ungapped. gap them to 0.8mm and that should do it. if u got cracks in ur coils look in the DIY section for a temporary fix, then save up for splitfires.
curently mine only does it in second after putting in plugs that i have not gapped down. So yes it can do it in certain gears as the load is different depending at what gear u in at WOT
So i guess first thing to do is remove the cover and check the coil packs. then if they look fine remove and check the gap on all the spark plugs? then gap them to 0.8? right???
:(:O
Edited by Adz2332
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
