Hi All
My name is Ron
Im new to this GTR thing and have a few questions to ask.
Firstly i have recently purchased a 93 R32 GTR and a PFC D-Jetro (thanks to Slide)
I was just wondering what would the costs be for -
1: to install and tune the PFC
2: to do a full service just to make sure everything is ok (as in change all fluids, belts, pumps?? )
and any other things that i should have looked at while its in the shop.
Any help is greatly appreciated
Thanks
https://www.sau.com.au/forums/topic/159601-service-costs/
Hey Ron!
and welcome to SAU and SAUWA :P
i can only help with my question;
-im not sure about the cost of installing the PFC. But tuning should be between $400-$600 for your 1st tune.
Best to give some of the workshops around perth and call and they will be able to quote you up.
Check out the The Consolidated Workshop thread
http://www.skylinesaustralia.com/forums/in...howtopic=141454
for a list of workshops NOR and SOR.
My personal recommendation for NOR is Hyperdrive (for tuning/services etc)
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2963186
For a simple oil change in a workshop (eg XSpeed) you're looking at $180-$217 depending on the quality of oil used.
GT-R, go for the $217 one. They will also give you a report on what work may need to be done and the general overall condition of your car.
May sound like a lot, but it costs me $100 minimum to do my own oil changes, ~$90 for Mobil1 and $10 for a genuine Nissan Oil filter.
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2963228
im due for my big service now, going to in tune performance, located in bibra lakes SOR, getting timing belt changed, all fan belts changed, coolant replaced, oil replaced, safc dyno tuned, walbro fuel pump fitted. costing $800.
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2963366
hey pal, where in bibra lake is that? i live there never seen it. Is the Walbro fuel pump included in that price or are they just puttin one you have in? i have also never seen your skyline around the area either :D
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2964454
Thanks for all the info guys.
I live south of the river in beckenham.
I was thinking about goin to Top Racing but havn't heard much about them.
Xspeed seems to be the most recommend workshop so i might pay them a visit
to see what im up for.
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2965192
top racing provide good service and treat customers with respect unlike some other known shops.
plenty of people will recomend them on here
$217 oil change is a big big rip off, surely pulling a filter off and undoing a sump plug isnt worth $130, its about a 15-20 min job max. i suppose its good value if u got a 15L sump :P
Edited by CruiseLiner
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2965726
Top racing really know their work.
Every workshop has their pros and cons. But put it this way I'm yet to find a performance shop that stand behind their tune an ensure their work. The only other place I feel can do this would be Top racing after having dealt with 2 very well known performace shops when it comes to tuning the power FC D-Jettro, both their service and tune were very very poor indeed espically after "paying for what I got".
Rob
Edited by dan_the_man
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2965816
give Top Racing a go
they arte the only workshop that touch my 93gtr
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2966315
Hi all again
I think i will go to Top Racing. I gave them a call and were really helpfull.
Just have to wait till i get PFC and then im booking it in.
I will ask about a leakdown test to see what condition the engine is in to.
Once again thanks for all of the advice and recommendations.
https://www.sau.com.au/forums/topic/159601-service-costs/#findComment-2968648
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
    • Don't use that manifold. Please don't use that manifold. Sunk cost fallacy is not worth the later pain. None of these will be relevant to the change that will come from the different turbo and manifold. As in, the effect of the exhaust will be nil, regardless of what else is changed. And all the cam and fuel system stuff is not changing either way, so has no effect. The turbo and manifold (and to a small extent the wastegate)....big change.
