Hi guys,
I liv ein brisbane and i am about to purchase a turbo for my r33.
I have been trying to decide what set up to go for for 2 months now.
I am thinking a slide highflow either a max rb25 over size or a vg30 max over size.
i like it becasue of minimal fuss bolting it up.
My Tuner recommends a gt30r and installing a thicker headgasket.
Now this is a lot more costly and if i can make a realible 250rwk with a slide highflow with supporting mods
then id rather do that.
I wanted to ask if any one has a slide highflow in brisbane that i might be able to see in person or meet at a cruise some time? i think seeing one perform in the flesh will help me decide what to buy more comfortably.
So far i have
rebuild forged pistons
PFC
walbro pump
metal intake pipe
FMIC
Catch can
I will be installing injectors and Greddy fwd facing intake and sllpit dump at time of turbo install.
And below a pic of the car.
Thanks in advance guys
Edited by tmc_2
https://www.sau.com.au/forums/topic/159614-highflow-turbo/
Hi guys,
So far i have
PFC
walbro pump
metal intake pipe
FMIC
Catch can
Much the same situ as me bloke. I drove a lot of peeps nuts with questions before i made my choice.
My mod list will be much the same as yours sans forged bottom end and my goal is 250 plus rwkw with as little lag as possible and fat fat torque. After speaking to members tuners and arron I ordered his stage 3 jobbie. All evidence points to this unit doing excactly what i want. GL with your decision.
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2963607
Fine Line,
Thanks,
Make sure u kepe us posted how u go after install.
I want to see a stage3 in the flesh pumping over 235rwk reliably then i will be sold. i can live with 235kw from a stage3.
If any one has a slide highflow id really appreciate it if i can meet you out on a cruise some time to see it first hand, seat of the pants whould be great .
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2963616
By stage 3 we mean the maxrb25 highflow.
DAN666
Im leaning towards the vg30 max oversize!
Im prob just over analysing??? i really want to have good response and performance wiht a 250rwkw power figure.
Injectors & AFM on the cards for sure!
Dan what tubz u running?
Edited by tmc_2
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2963622
Thanks Noel, mmm when he first started I was considering one and at that time he said he could do a 270 degrees bearing for an extra 300? but I never followed up on it.
This mod deal is like getting presents. you dont know whats in there till you open it up.
To a man everyone says that with the mods we are using (or going to use) 250 rwkw is a shoe in. However, There are cars out there carrying these mods or more which arent making those figures.
Still the great unknown (for me at least) is the puda. i simply cannot get a definitive answer. I would like to know excactly what are the desirable features in an engine management system and which if any of the known brands have all the fruit.
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2964200
Id be keen to buy a better bearing i guess for abit extra like that.
I guess i will decide in the next 2 weeks.
Id be realyl keen to see one in action if any one in brisbane has one!
I pedalled Lazy bastards 33 last week with this same type of mod setup tmc. It hauled arse through the midrange. very useable power. Very impressive.
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2964315
Id be keen to hear from lazy bastard33 and toy-33, be good to see there set ups in action.
Migh shoo them a pm if they dont join in on the thread :D
im really for hte slide due to cost, but for an extra 600 if the GCG one shows its worth i might consider it.
Useable power is what i am aiming for mainly.
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2964381
i have a max size slide highflow - 231kw at the wheels on mercurys dyno
couldn't get the vg30 as he was out of stock of exhaust housings, has he found more supplies now?
so like 180 rwkw everywhere else?? :D :D
What boost are you running for that figure Izaac? I am assuming there is a bit more left in it?
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2964682
so like 180 rwkw everywhere else?? :) :)
lol true :( i wonder why old men in camrys still outpowah me :(:P
15psi, yes plenty more but requires upgrade to fuel system as the injectors are near maximum duty cycle. I run stock injectors, stock regulator with a walbro.
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2965024
its really really really hard to go past a powerfc
theres a reason we all use them hey?
i saw your comment in the other thread, tuners for powerfcs will be around as long as you own your car
https://www.sau.com.au/forums/topic/159614-highflow-turbo/#findComment-2965156
    • It's sodium citrate, I misspoke earlier. It's a citrate buffer solution. And yes, depending on how thin the metal in the tank is this may or may not be a wise decision but if it's just mild rust it should clean off and it should be fine.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
