I Lost A Cylinder
yokotas13
 Share
Ok heres the problem
I hit a bump, and BAM
Shit started smoking, adn through elimination its #1
WHen you unplug the fuel injector it is fine, smoke goes away
plug it in, smoke city
it runs on 5
when i plug #1 injector in, it wants to die in like 2 seconds flat, and will only stay running, barely with some throttle.
all 6 plugs have same appearance
all 6 cylinders have same compression, wiht no loss within 5 minutes of pressure.
i cant figure this shit out.
any ideas?
I also swapped #1 and #2 fuel injectors, same problem
i haevnt done the coil packs yet.
  • Replies 50
*yep, all that suspension expertise is REALLY paying off now*
Sounds like a spark problem - try swapping over the coil packs to be sure and have a really close look at the casing when you are doing it - a break in the plastic coating could be shorting out the spark.
Also check all the obvious stuff like ecu plugs, injector connections etc.
Just be careful - if the piezo is stuffed you may be pumping raw fuel into your turbo (which would explain the smoke) and that won't be doing thebearings or seals any favours whatsoever.
it was tyres,not suspension. He told me he knew everything already,so I haven't seen a need to reply to any of his threads since. I have a theory for this one as well,but since yokota knows better than us,I'm sure he'll find his own answer.
Justin...
I dont think you guys should be so facetious, he asked a valid question and asked for help. I am sure if this was anyone else he would've not got the responces that he has.
So either post helpful things or dont post. We are not 5yrs old here and this is not a playground, so grow the f up!
Oooh, testy!
I was just making the point that having lowered the car so much, restricted suspension travel and removed any cushioning effects offered by a sensibly sized tyre sidewall, the chances of anything going bang over a bump is greatly enhanced.
I was not being facetious. I did try to offer some help so back the F off! Blanket statements like that don't do anyone any favours.
and have a lovely day..... :D
Oh, and Yokota's, when you do get this sorted, make sure you at least check and clean the O2 sensor in your 'zorst because right now it will be coping a hammering.
Edited by newbie101
my suspension setup has nothing to do with me hitting a huge ass dip/bump in the road retards.
shit happens, and im trying to fix it.
when you push boundaries shit breaks. its part of the territory
But, im slaving 6 coilpacks form another r33 tomorrow to see if it fixes it.
it should just be a bad coilpack hopefully
Look, i fit the wheels, suspension and everything works
Its not a perfect ride, but se, i know it wouldnt when i did it
You guys said it oculdnt be done, i did it. now dont be sore asses and deal with it.
and i just found out a friend with a 32 GTR had the same problem and it was a coilpack....after hitting a bump....with nothing near as low as my car.
even if i have a series 1 stag?
but on a sidenote, who cares what caused it (a huge dip int he road), lets try and focus on the answer. I dont know much about rhe RB series motor, which is why im asking about it
No, but what you did to the suspension WILL have an effect on how your car deals with the impact
Nobody told you it couldn't be done, you were just told it would be impractical, cause more drama's down the road and cost you more money and heartache. If you continue with the pedantic whining know-it-all attitude you will be finding it harder and harder to get useful information from anyone here. I'm just glad I don't have to deal with it - you do! :P
If you need any help with the RB series engine and diagnostic, post here
http://www.skylinesaustralia.com/forums/in...php?showforum=8
and show some of them guys the same smart arse attitude - see how far it gets you.
look, its not know it all
its that i know what i can do with a suspension
whether its ideal, practial, honestly doenst really matter. Most things i do arent really the best.
But i know it works, its not efficient which is why i am workign on a custom coilover setup
But when on an engine issue such as this have i been know it all?
I havent, so it doesnt belong in the thread
for all i know the bump might not have had anythign to do with it, or it could have. But shit happens, and im willing to pay for it, i just am looking for ideas to help me figure out how much i have to dish out.
but on a side note, i do apologize if i did piss anyone off, or come off as a know it all
I just am a smartass by nature, 4doorwhore knows it
Im hardheaded, and work at things until i get htem to work...its just how i am
what? who are you?? :) haha
That does't sound like a crook coil pack. If it was, there would be no difference between having the injector plugged in or not.
Sounds like the injector is being held open the whole time. Try to get a dwell meter or CRO to check the injector pulsing on that injector. Sounds like it's holding that injector open the whole time.
problem is, if that was the case it would be black smoke, not white becuase it would be pig rich. thats why i eliminated that factor.
but ill check them
 Share
