http://www.bom.gov.au/cgi-bin/wrap_fwo.pl?IDQ20038.html
Just in registered at BOM
Be aware of them, just the quick heads up guys
Registed at 6:20pm Just thought id post it up in the case those who may be in the path
Cheers
A
https://www.sau.com.au/forums/topic/159655-severe-thunderstorms-se-qld/
  • Replies 86
pretty light show happening around here atm. (Amberley) Sure hope it has some wet stuff in it as well.
see if you can get some pics.....
if you have a real (SLR) camera, just open the shutter til the light show finishes and then that hsould be an award winning photo :)
sik.. heading straight for the dams.... although looks like it will be a quick inny and outty which probably won't do much, other than smash stuff..
Its below the catcment area but :) needs to fall half way between Toowoomba and Kingaroy for the head of the river and largest catchment area :)
You mexicans are lucky as, we've only had one decent storm up here so far this year.
All we get is loads and loads of rain...
*sigh*
but seriously, if anyone can get some storm photos you should post them up so we can all have a captain cook.
*sigh*
it looked like PD and mossman got pissed on today.....
well out at the beaches we only had alittle.......
we did get a good thunderstorm about a month ago though.... best for years.....
Yeah I reckon, spent that night trying to stop the house from flooding. the old man copped a bolt up the leg from a lightning strike hitting the water we were bucketing out .... ahh the memories
Edited by Ol_Mate
you want rain, have a look at port headland. you can see the bloody cyclone.
http://mirror.bom.gov.au/products/IDR162.loop.shtml
That's f**kin nuts
did you see it during larry last year....
in fact monica was worse a far as rain went. it pissed down for nearly two months,,,,,,,
