have a look in the Classified section at the top of this forum.. if you don't find any in there that u like, check out the SAU Australia classifieds as well... you'll get a much better car/deal from here than any dealer will get you.
https://www.sau.com.au/forums/topic/159660-skylinee-in-qld/#findComment-2964927
strik3r knows what time it is
time to use the "search" button :P
But seriously, what strik3r said, failing that,
www.carsales.com.au
www.tradingpost.com.au
failing that:
motorman imports in springwood
many more import yards around brisbane area....
https://www.sau.com.au/forums/topic/159660-skylinee-in-qld/#findComment-2965264
MJR motorsports on the gold coast are good, i bought my car from there, First owner here, and the car is immaculete all their cars are, and they buy them as stock as they can, wont find many modified ones there, they are a bit pricey though, I payed well over what my car is worth. I dont care the though the condition and the k's make up for it.
http://www.mjrmotorsport.com/
LOCATIONS
Retail Showroom/Yard
Open 8am to 5pm Monday to Saturday
40 Ferry Road, Southport Qld 4215
Ph: 07 5532 7956
Fax: 07 5532 7952
After Hours
Murray 0416 080 127
Steve 0418 797 709
Alex 0411 616 617
Japan 0011 81 90 3878 1114
Email- [email protected]
Performance Workshop
Unit 2, 44 Dover Drive
Burleigh Heads, Gold Coast Qld 4220
Phone 07 5520 7909 Fax 07 5520 7909
After Hours Lee 0417 649 983
Open Monday to Friday 9am to 5pm
https://www.sau.com.au/forums/topic/159660-skylinee-in-qld/#findComment-2965404
Warranty...hahahaha thats a good one....I think i might have peed a little........oh wait, you weren't joking?
Seriously mate, take everyone's advice in here. Warranties on second hand cars (especially performance cars) bought from a dealership are about as useless as trying to eat soup with a fork. Save yourself the money and get a private sale car checked over thoroughly from a reputable mechanic or workshop.
But hey, it's your money.
Matt
https://www.sau.com.au/forums/topic/159660-skylinee-in-qld/#findComment-2982447
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
