G'day guys,
First post for a looooooooong time.
I was searching through the shed today and stumbled across a few things from when I had the R33 and Stagea that someone might need.
First off, this is Canberra pick up only (hence why I'm posting it here). I'm down tuggers way so if you want them come and get them :)
I've got one brand new black leather R32 gearstick boot left over from when I was making them up. I don't have the handbrake boot though. So it's just the gearstick boot. If you want it, come and get it..
Next is a factory blow of valve from a R33 that's been modded. All that's been done is a screw has been put in the small recirc hole, it'll hold a little more boost and give you a cool noise but nothing loud. The screw is easliy removed.
And last is the pipe that runs from the right hand cam cover to the pipe that runs back to the inlet pipe. I removed it on the Stagea cause I installed a oil catch can there instead. It's NOT the pipe that runs between the left and right cam covers. It has the factory clamps on them too.
Post up here if you want the stuff (don't PM me). First to post gets them.
Again, pick up from the tuggers area only.
Cheers
J
P.S. payment can be a drive in your skyline - it's been a while since I've been in one!
https://www.sau.com.au/forums/topic/159683-free-stuff-canberra-pick-only/
Tomosan - cool, the gearstick boot is yours if you want it. How does saturday morning sound to meet up ? I'll drop you a PM with my phone number.
SkyGTRLine - if Tom can't make it to pick up the gearstick boot I'll let you know.
G'day Shell, yeah long time no hear. I still browse the forums no and then but don't post much. How's things been? I think that's all for free bee's, but I do have another shed to go through yet.. lol
StinkyPoo - cool, the BOV is yours. same as Tom, how does saturday morning sound? I'll send you my phone number too.
Leech - How's it going? Hows the R33 going? I see you buzzing around occasionally, the car still looks really good - touch with the fmic :) how did you go with getting the gauges into the center console under the AC?
J
Hey Jay, how goes it?
G'day Term - yeah been good this way. Busy with a new job and so on but everything is cruising well.
How's the Stagea going ? What sort of mods have done to her since I last saw you?
P.s. - PM's sent to Tom and Stinky ;)
You know, I asked for a hand brake and gearstick boot about five lifetimes ago..................then it all went quite. I took it that the war was over!!!
Jay if your still making them, OR if you made mine then wondered wtf, then I'm ready......lol
Things have been good Jay!
Let me know if you find anything in the other shed that I might want :):ninja:
so do you not have the stagea anymore? i still remember that day i walked out and found you parked at my back door... sooo random! lol
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
