I’m having a few running and refinement issues with my manual converted S1
It has 172awkw on .7 bar with all the usual mods. If I run any more boost it just retards the timing and I get a very uneven power curve. It has an SAFC that I had tuned just after the manual conversion. When tuning it they leaned it out all through the rev range and maybe a little too much at idle. The tune gave a 40awkw power increase and massive fuel economy improvement. I was hoping it would stop it back firing and shooting flames but it still dose it.
On closed throttle down hills or coasting between 1500 and 2500 rpm I get a constant pop pop pop pop pop from the exhaust.
On up changes when giving it a bit I get a big kaboom with a bright flash out the back. It’s like I have a jihadi with a rocket launcher firing from my boot.
Since the tune, on cold start it also idles very rough. Which I think is because it is too lean, when it worms up a bit its fine.
The only thing I can think of that could be causing the popping and flames is some sort of ignition cut on closed throttle or the injectors not closing off fuel supply properly.
Any ideas?
I would like to be able to fix it without having to go to programmable management.
Any ideas?
sudden rich mixture when u back off the throttle, thats what mine does and monster flames lol :P
must admit mines because of the cams i got, dont know why yours would do it :D
I changed my plugs from Iridiums to Coppers, and it got rid of the cold-temp misfire and sluggishness straight away (it would run better when it's warm, but still not perfect), but the popping on over-run is still there, but apparently that's quite normal.
The copper plugs made a fair bit of difference, and at roughly $25, it's a good place to start before you go chasing replacement coil packs, etc. I checked my coil packs when they were out, and visually they looked fine - no cracks to be seen.
It sounds like it might because the timing is too advanced on the exhaust cam.
It’s not the plugs or coils. I’m running spit fire coils with iridiums. I did have a miss problem before I changed the coils and plugs so know what that’s like. The cold idle problem is like starting a carby car on a cold morning without a choke. I have to give it a bit of throttle to keep it going and the revs dive and peek between 200rpm and 1000rpm once it’s wormed up a little its smooth as.
It’s don’t think its running rich and moods shouldn’t make it richer with the throttle closed on the stock ECU.
Thanks for the ideas
Mine had a similiar problem, turned out to be the IAC valve & the 02 sensor. Cleaned the IAC out (actually I cleaned the throttle body at the same time) & unplugged the 02, fixed it right up. Later after I converted to manual I found it did the pop pop pop pop down hills etc & I could basically make it backfire when ever I wanted by giving it a rev on down changes...........loved it!!!!!! :w00t: It would also do big floating flames out the back & the occasional backfire on up changes. I replaced the ECU & it fixed it for a while until the ECU re-learned itself.
Engine was stock apart from 3" exhaust, FMIC, Pod & HKS SSQV. The sad part is my RB26 doesn't do it, well it did while I had no exhaust but not anymore :O
My 260 does the same. dont mind it at all, flames are great! I have very little getting in the way from the turbos to the tip so that may be another reason.
Flames are all good fun until you’re accelerating out of a RBT, change into 3rd and kaboom there’s a huge orange flash and you see the cops diving for cover in the revision mirror.
The pop pop popedy pop starts to get annoying after a while too.
    • I know it's an entirely different engine, but I noticed practically 0 difference removing or adding 2x 3in (5inch body) 400cell cats (one in each bank) with regards to sound. So changing the cat to change drone I suspect will have very very, very, very, very, very very minimal impact.
    • 200 cell cat will probably help. Do you have room to tee off a Helmholtz resonator anywhere along the exhaust? These can do wonders for drones, with a little experimentation with regards to length.
    • The car revs up through the gears much better/faster now, and fuel consumption doesn't really seem to have be affected either on a Hwy cruise, which wasn't expected  The FAB9 intake manifold has been problematic sourcing though, I've contacted Plasmaman to ask about their intake, which you can get different runner lengths spec'd, and, their different options for throttle bodies  The only real physical drawback with the Plasmaman intake is how to connect it to my current OEM style airbox, as FAB9 make a OEM style back half of the airbox to suit the larger diameter throttle body, and all that is required is a 30°bend silicone pipe to mate the throttle body to the airbox Car also goes in for some exhaust work in a week or so to fit the biggest resonator they can fit clearance wise in the front pipe to help remove some of the drone, there isn't alot of realestate under there, a rough guesstimation is it will only be about 3-400mm long and maybe 90-100mm diameter, and with a 60mm exhaust that doesn't leave alot of space for the internal volume of the resonator to do its thing I'm thinking I may need to bin the "high flow" 100 cell cat for something a bit more substantial, yeah, and restrictive, like a 200-400 cell, to help, but, I have ample room for a really large bodied cat to replace the current one which has around a 4" diameter body I may look around in the recycling bins and see if I can find a massive newish cat that was "replaced" with some new full exhaust system that the local exhaust shop in Western Sydney is doing
    • Hahah look at that smile 😂 Just like those ones on IG where they compare the husband in family photos vs husband going fishing lol. I don't think I'll participate this time, clutch isn't in and also the last time I went there were too many numpties on the cruise sessions. Nearly caused a few accidents holding up people and a few guys initiating massive kerb to kerb drifts with heaps of cars right behind them. Not to mention, there were guys on the track session using it as a power cruise session.
