hey im trying to change my name on here, and i cant seem to figure out how to do it - ive even tried contact administrators and no one has gotten back to me
id l ike to either change my display name, or just delete my account and create a new one with the new name...
would be great if anyone could help =]
p.s i did try to use the help topic too
https://www.sau.com.au/forums/topic/159703-help-with-change-of-display-name/
name change is done
login is "lucy in the sky"
ps nice play on words
thanks for helping me with that =]
i was gonna pm you but werent sure if you were the right guy to ask.
hopefully soon i will actually have a skyline in my possesion so the name will make sense, at the moment its a bit of a lie haha
ohhhh yeah lucy in the sky-line got ya now
i thought u were a pilot. or a hippy
    • A work around is to install the R35 card style AFM/MAF on the cold side of the intercooler piping and the BOV on the hot side piping. Works well, also you can combat the revs dropping by adding a bit more ignition timing on the idle ignition timing table to slow the rate of RPM drop.
    • Understood. If you dont have a ridiculous limit,  Tune, T's and P's are in check, and arent bashing it all the time and doing the due deligence for maintenance(inc oil analysis) then its pretty safe. 100% agree, let your right food control it to some extent.
    • So these external kits with the machined block for remote solenoid mount will only work on a NEO head and RB30 or RB26 bottom end   For an R33 head on a 26 bottom end the remote vct kit is to resolve RB26 manifold adaptor plates etc  IF you try to use the remote VCT on an RB30 or RB26 bottom end with an R33 head then  you can starve the cam journal??? I have one of these kits from bits I had years ago before plans changed  I don't understand how that tracks with this video   https://youtu.be/RuPiI22Mplk?feature=shared   This looks like I can run the v termite vct kit to feed the VCT on an R33 head on an RB26 bottom end?!?!?   Lol.... don't v have these problems on RB20s
    • Yeah i know that MAF is no no for this type of BoV. The engine has no BoV and "hose/pipes" ..it was all deleted (or probably it was not even on the engine when it was bought  ) It does that "sutututu" noise which i kinda do not want(atmospheric is better IMO...but standalone ECU)  What are the cons of running without blow off on stock RB25DET NEO. It running 5-7 PSI max (it has boost controller)   EDIT: and can Nistune be "tuned" to know there is no BoV to i dont know "know" and be better for a car? I read so many info about no BoV. One guy saying it is bad and hurting the turbo/engine/car and other that it does not...
    • Yeah. OK. I'll say the same thing I say to everyone. You do not have to use 100% throttle all the time.
