has anybody have a picture of a standard rb25 rod they can post for me. reason being as i recently sold the standrd rods from my rb26 and the person has emailed me saying their mechanic is sayig they are rb25 not rb26 rods where i know for a fact they came out of my rb26. just want picture of the 2 to send to the person and compare. What visual difference is there between the 2. Anyones help would be appreciated.
Cheers, scott
here are pics of the rods that came out of my rb26
Edited by OFENSV
https://www.sau.com.au/forums/topic/159710-rb25-vs-26-rods/
my gtr rods had this stamped on them 20-3<>05u41-1 and im pretty sure my stock rb25det rods had stamped on them 24-4<>05u41-2. does this help? i have photos with them side by side. if you would like the pics just pm me your email address and i will send them to you.
is that pic you sent me all rb25 rods? i cant tell the difference between them and 26 rods.
https://www.sau.com.au/forums/topic/159710-rb25-vs-26-rods/#findComment-2969201
I found a couple of pics but they are not the best.
rb25 rods - blurry pic
rb25 rod
Well i don't know if they help but regardless the pic you have shown is clearly of rb26 rods.
They are much thicker where the beam tapers into the big end and there is more material around the bolt holes.
If you compare the pics of the rb25 and rb26 rods you can clearly see the rb26 rod beams start to taper out wider closer to the little end than the rb25 rods. Using the protrusion on the side of the beams as a reference.
It's a shame you have to defend yourself against the word of an obviously incompetent "mechanic"
https://www.sau.com.au/forums/topic/159710-rb25-vs-26-rods/#findComment-2969225
here you go mate
thanks, i recieved an email the otherday from him saying he had taken them to another mechanic who confirmed they were RB26 rods and the guy showed him a 25 rod to compare the difference. He said the second machanic couldnt believe that the first mechanic said they were rb25 rods. Ohwel all good and sorted now:)
https://www.sau.com.au/forums/topic/159710-rb25-vs-26-rods/#findComment-2988059
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
