Thank you all for the encouragement and advice.
I like the white interior...but we'll see how easy it is to live with. The rear wing has been put back on so i'll see which I prefer (on or off).
Oh, and I do not beleive it to be a VSpecII.
While it has the brembo brakes strut braces, I'm sure the vspecII's didnt come out in '92.
The only remaining way I have is to check the codes printed on the attessa controller methinks....
To me, The brakes were the most important part of the VSpec.
I'll let you know how it goes!
Cheers
f
either way having the brakes is good!
the 33 gearbox would be quite a good thing to have, the clutch packs in them are electronically controlled as opposed to the hydrolic system in the 32, which makes it alot more responsive.
Ive often thought about getting a 33 gearbox for my 32 but im not sure what would be required to wire them up, and I have better things to do with my money
Id just like to add the following;
1. I have worked on that car
2. I have driven that car
3. I remember the day it was pulled from its container and loaded on to a flat bed
4. It used to be (in my mind) the cleanest GTR in Australia (hopefully still is, have not seen it in over 3 years)
5. I envy you, this is a beautiful car
I would love to see her again, please bring her to a Tuesday night dinner soon...
Cheers Col
Cheers Col
were you/are you in <3 ??
Col,
Tuesday night sure! When and where.....you might be able to clear up a couple of things for me....
Oh, by the way the experience has been good so far. The battery was a bit flat so some of the warning lights were coming on. Put another battery in and its been pretty nice......until you boot the loud pedal.......then the fury is unleashed!
Cheers Col
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
