I installed a EL gauge kit in my r33 and I took it for a drive, adjusted everything but till correct but the needles sort of 'stick' at certain points. The speedo isn't as smooth and neither is the tacho. it's pretty accurate but I'm unhappy with the jerkiness of the needles. Anyone who gets in my car comments on them jumping around. I thought about restoring them back to the factory ones but I doubt this will fix it. Did i press them onto the shafts too hard? would a bit of WD40 or contact cleaner help?
LED's focus the spread too much giving hot spots like in the photo.
Had them in my stock speedo cluster and it pissed me off alot, so went back to stock bulbs. They spread evenly.
Not if you use the right ones....
What are you kidding?
Can you not see the focus on 2000RPM, 20-40km/h, 7000-8000rpm, and 110volts and 180km/h??
Poor example :bunny:
Edited by gotRICE?
  • 1 month later...
