Some of you might remember this car from ZOOMs Project 11s series of stories. Since our track shut in SA (AIR) we cant really complete the story, but here it is, in full 11 second capable trim, department of road transport approved and registered with an RB26DETT for $15,000 ono. Heres the specs -
1992 R33 GTS 4 door
Engine -
RB26DETT R32 GTR engine, rebuilt by Willall Racing to factory specifications (5500km since rebuild)
R33 GTR cranshaft and oil pump used during rebuild for reliability
R33 GTR Intercooler
Stock turbochargers
Power - 244rwkw @ 1.0 bar boost pressure
Performance: 12.56 @ 115mph (AIR 4,6 and Rotor nats)
Transmission
Nissan RE50A 5 speed electronic automatic transmission
Fully built by MV Automatics with extra clutch packs, modified valve body
2800rpm stall converter
Electrics -
Apex Power FC engine management system
R33 GTR fuel pump
Chassis/Brakes
HSD Coil Over adjustable suspension
R32 GTR Braking System
R33 GTS-t 4.11 ratio LSD
Body
R33 GTR Front bar (genuine)
R34 GTT rims with good condition Wahnlis on board :)
This is an extremely quick and bulletproof reliable car that will run proven 12 second passes on street tyres at the drop of a hat, get 10l/100km fuel economy around town, and is legally registerable and insurable in any state of Australia, so no reason to be scared of a defect. This car really is the ultimate sleeper!
Any interested parties enquire by PM....and the car is available for viewing in SA :D
https://www.sau.com.au/forums/topic/159730-sold/
Heres the engine on the stand after it was freshly built ;)
Then after Willall Racing installed it back in the car with the factory airbox and all of the correct GTR parts including an R33 strut brace. This car is the real deal, and ran its 12.5 second pass through both the stock air filter and exhaust. Its a brilliant package :D
https://www.sau.com.au/forums/topic/159730-sold/#findComment-2969346
mate if i can sell the 180 (or you want a trade even with a bit of cash ur way) consider this sold ;). Im inadelaide too
We are selling the car because we are moving on to other projects. We also dont need to try and make a profit. This is realistic price for a properly thought out and modified car :D
If anyone here knows Willall Racing they will know that their 8 second GTRs are perfectly presented and well engineered, this car is no different. Thats why I had it built by the best :D
https://www.sau.com.au/forums/topic/159730-sold/#findComment-2969405
sorry, i know its off topic, but are you allowed to give out any clues as to where your going next in terms of project cars? im a loyal fan of both zoom and HPI, so gimme the scoop ;)
Edited by VB-
https://www.sau.com.au/forums/topic/159730-sold/#findComment-2969466
sorry, i know its off topic, but are you allowed to give out any clues as to where your going next in terms of project cars? im a loyal fan of both zoom and HPI, so gimme the scoop :D
Nice one....the project cars are secret at this stage :worship:
https://www.sau.com.au/forums/topic/159730-sold/#findComment-2971567
    • I was just going through this on Neil's car (33 gtst). Assuming you are using standard AAC and Cold start valves, you need Post Turbo Pre throttle to Boost Controller (if you have one) then to Turbo Wastegate Pre throttle to AAC input AAC input T piece to Cold start input Cold start output to plenum post throttle AAC Output to plenum post throttle AAC Output to brake booster (needs a 1 way valve) Plenum post throttle to Fuel Pressure Regulator Plenum post throttle to Blow off valve signal Plenum post throttle to Boost controller input (if you have one)
    • I’m trying to figure out the purpose of these fittings. Assuming they’re for coolant but not sure where the lead to. I know the bigger one on the right (which isn’t filled) is the brake booster. If anyone has a photo of a diagram of this intake or has a set of instructions it’d be greatly appreciated
    • How much is that r32? Is that $170k or $1.7m
    • Ahhh! My silly brain was thinking Nissan started selling them straight away, but they waited w or three years didn't they?   Maybe Duncan should build an R35 race car over the V37... There's a cheap yellow one on car sales Duncan, would only need your splash of purple added...
    • Welcome (back) Gaston! Keep us up to date with the hunt!
