ive herd both ways one had more brod voltage than the other. Tryin to figure fact from fiction for a freing considering both of these. What sort of power can be expected at max so I can give him a good example! Thanks in advance guys. Sry if its been posted. I did search and came up with nothing :P
https://www.sau.com.au/forums/topic/159763-q45-afm-vs-z32-afm/
all airflow meters max at 5V there operating range is 1-5V the only difference is the resolution, and the air speed through the meter itself, that is air has a higher velocity through a 70mm pipe than a 80mm pipe for the same volume of air.
Hope thats clears some things up.
Cheers Matt.
