Was driving my sister home from Freo last night coming down South Street past Coats Hire towards Stock road.
A cop car had blocked the far left lane and had a fully laided double B road train in front of it. Moving into the right hand lane to go around I saw why it had happened.
The Road train had mounted the kerb and gone across the verge into a side street taking out a brand new 911. The roof of the car was 5 feet in the air and the a pillar was where the gear stick should have been.
I don't see how the prosche driver could have survived. Really sad as he had no chance.
I've seen a lot of major prangs but this one was unbelievably bad.
https://www.sau.com.au/forums/topic/15977-this-really-screwed-me/
I know a guy who's Dad brought him a 200SX. Flying down the road on a wet day and sliding sideways into a tree he killed himself and 2 others and the surviving one has his legs amputated from the knees down. That was really sad.
I saw 2 bad crashes on Armadale rd yesterday (thu) morning on the way to work.... one involved some little red car like an old barina or soemthing. was fully masshed and the roof was cut off...i assume the firebrigade did this to get the person out.
Didnt look like they could have survived it! but i havent heard anything on the news so hopefully they did. Makes you slow down but!
Seen a mates car this morning sideways in some bushes. Seems his g/f was driving, booted it around a round'about it kicked LSD and 180 degree spun up the kirb and plowed into the buhes on the opposite direction they were originally travelling. Mmmm, not good, they are ok and they were lucky how well the car came out of it. Still has some big dents though. Smashed front bumper too.
witnessed my mate put his dads jag xk8 ~$200k car into a lightpole... outside applecross maccas, was only at about 30km/h, spun it round in the wet (traction control off ;)) and poled it. got out a bit shaken, but thats all. oh and damage was $60k worth :( somebody sent these pics into fastfours mag and it was featured in there... no idea who, it wasn't any of my mates.
pic 1
pic 2
and a pic taken earlier that day
pic
oooooooohhhhhhhhhh so its just a feature. It just came with the car, wasnt something i was choosing. Besides sensing these 2 features, can it be used in any other way. Well my active lsd light always turns on when I start driving, but slip turns on when I'm hooning. Do i have to be concern abut the active lsd light always on? thanks
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
