Hey everyone,
I am very interested in buying this car. I was wondering if people could give me any advice if this car is an awesome buy or a Lemon.
This will be my first GTR so i am a bit nervous and if peopel could give me a quick run down on costs that i might not know the GTR's might need ( I already know they need oils changed every 5k kms, Spark plugs should be done around the 15k kms mark, petrol, tyres, insurance and a tune once a year and have already calculated that so i am just after any costs i havnt mentioned up there)
Car engine is already fully modified and was built in Japan with a few suspension and exhaust mods done here in Aus. Only reason i am concerned is that the engine was built in Japan and the exact specs of the engine cannot be confirmed or anythgin along those lines.
From what i gather the car would have been a track car or a drag car in Japan so any advice on what to look for or areas to be cautious about or just to avoid the car would be greatly appreciated.
Should i get a compression test and a mechanics report before i view it and test drive it?
Does the price tag of around $26 sound right?
http://www.skylinesaustralia.com/forums/in...sg&id=86332
http://www.skylinesaustralia.com/forums/in...sg&id=86333
Dynoed at 20psi 360rwkw, 300rwkw at 1 bar tuned by JEM, these are safe tunes as its used as a daily driver.
96,000K on clock
2.6 litre twin turbo coupe with anR33 GTR engine and Trust 618z turbos
ENGINE AND ELECTRONICS
APEXi Power FC and FC Commander unit
HKS EBC
Forged Pistons
TOMEI 260 degree cams
TRUST adjustable cam gears
HKS 1.2mm head gasket
HKS metal gaskets for plenum and exhaust manifolds
Sard 680cc injectors
SARD fuel regulator
N1 water pump
HKS delivery pipe
Bosch intank 044 pump
Polished Plenum
Oil catch like the powerplay ones + oil Air separator
Cusco Intercooler Intake pipes with Custom Turbo Intake Pipes (aluminuim)
Custom Carbon Fibre Air Box with CAI
Cusco master cylinder brake stopper
Z32 airflow meters, new apexi pod filters
Dual core radiator with cusco air panel diverter
TRUST dual core Intercooler 75mm
TRUST oil cooler and oil filter relocator Power Enterprise magnetic oil filter used
OS Giken twin plate clutch with lighten flywheel
R33 Brembo brakes front/rear with Earls braided brake lines F/R
NISMO circuit link suspension parts
AS - front pillar brace bar, for more rigid chasis
Chasis has been Pop Riverted for extra rigidity from engine bay to front cabin
Adjustable Front Upper Arms (camber)
G4 - Height and dampner adjustable suspension
ARC adjustable castor rods
Rear HICAS cancellation bar
ARC front and rear strut tower braces
ARC front and rear sway bars
NO ABS
TRUST dump/front pipes
3n1/4 inch Kakimoto stainless steel exhaust
Hi flowed Catco cat converter
Push Start Button with kill switch
Battery relocated to the boot
RWD toggle switch made by Dirt Garage
GReddy Electronic Boost gauge and HKS oil temp gauge
4WD controller by Raceworx installed (Duncan)
Turbo timer
Trust Gear Knob
3point immoboliser with auto window lifter, works with turbo timer
Rays Engineering 17x10inch rims, chrome outter and gold innner 2 piece rims 255x40
N1 front bar with front lip on bonnet (carbon fibre)
N1 head lights
N1 lip on the boot
N1 style side skirts
Kenwood MP3 player with Clarion 6inch splits, Clarion 6inch rear speakers
Any help will be greatly appreciated
https://www.sau.com.au/forums/topic/159773-good-buy-or-a-lemon/
Yeah, $26 sounds great for all that!! jeez, you could sell the gear knob for $50 and make profitttt!
just jokes! i guess no one else has replied so i'll throw in my 2c. i can't speak to this car, and i don't know your requirements. i'm not sure if the car is already in australia, but if i'd seen that the car had been used for drag or heavy track work, i'd probably give it a miss - that sort of activity can put a lot of strain on the chassis. also, loads of modifications could be a headache when the time comes to insure it. that said, if you want a beef monster, this looks like it might fit the bill ok. get a compression test done and perhaps even a decent workshop to look over it.
if it was me, i'd look at something else if i wanted a daily driver. but that's just me.
sounds cheap for all the upgrades on it.
FYI there is very little difference between r32 and r33 GTR engines (oil pump drive on the crank was late r33 and r34 only iirc) and with those mods it doesnt realy make any difference if it was a r32 or r33 engine.
be aware that these cars detiroate quickly when worked on the track or the strip, so if its going to be a driver it may be a bit of a pig.. if you plan to use it as a track weapon it could be an exceptional buy :nyaanyaa:
goodluck!
oh, also, check the compliance plate and make sure it wasn't brought into the country as a track car. if it was, you'll of course need a cams licence, and won't be able to road register it.
the links don't work so i can't check the thread you're indicating.
also the servicing you all metioned should be done even more regularly than you thought because it is a highly modified example
the more power you make, the more you have to service her to keep her from going bang (more power creates alot more stresses)
but other than that it seems like a good car for a good price
as with any car best way to know is to check it out ... compression test, leak down test, etc ...
Cheers
RellikZephyr
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
