of so i need money for a tune mostly but im sick of this stuff sitting around doing nothing
RB20
i have rb20 turbo very little shaft play $200
2 sets of cam gear $50pair
stand injectors work fine
stand plemum $100
rocket covers $80
rb26
standard cam gears $50pair now $20
stand plenum with thoatle bodies $600 price drop $400
twin turbos with dump and manifolds $600price drop $400
rocket covers $120 price drop $80
coil pack cover with ignigtor $200 price drop $150
cefiro
both driver side door $250 each price drop $200each
boot $200 price drop$180
bonet $200 price drop$180
front bar $150 price drop $100
rear bar $150 price drop $120
pasenger side gaurd $150 price drop $120
front and rear seat front seat $170each rear $100price drop all 4 for $350
dash $140 price drop $100
speedo cluster $160 price drop $120
radiator support straight not part of the car $300 price drop $250
i have a whole car there its all i can think of so if u need anything
just ask ive probally got it
i am negotialble but i have put the prices pretty low
to get a faster sale will post buyers pay post though
keen to swap parts if u have something i need here r a few
contact me on 0412938223
or just drop me a pm
Edited by drftnfrysi
https://www.sau.com.au/forums/topic/159805-cefiro-rb20-rb26/
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
