You can look it up in the Skeptics Dictionary - you'll find it between Haunted Houses and Homeopathy. To quote
"Hiclone promises fuel savings of up to 20%, power increase of up to 15%, and hydro carbon emission reductions of up to 30% with prices from $160-$215 (Australian). They'll even sell you something called Fuelmax which "is a magnetic frequency resonator which clips onto the fuel line and 'fractures' the passing fuel, allowing it to mix with oxygen more readily and thus burn more efficiently." This should keep you laughing for up to ten minutes"
The results were certainly good, although I onnly laughed for 5 minutes - perhaps because I'm an old bastard and remember the Brock Polariser and such.
https://www.sau.com.au/forums/topic/159841-use-of-hiclones/#findComment-2968915
Gav, Ant fit a polariser to your car, and it's making 1000hp now :)
https://www.sau.com.au/forums/topic/159841-use-of-hiclones/#findComment-2970709
Those so called magnetic stuff are crap. Same as broquet fuel catalyst or what nots. Wtf would something invented in WW1 be so amazingly applicable today that major maufacturers don't implement it? Think about it. Manufacturers would boost their sales if they can increase their fuel efficency with just a few hundred bucks. After all... whats a few hundred when u're paying thousands? Every car manufacturer, esp in the economy class, toyota, mitsubishi, etc.. are trying to get better fuel economy so as to promote their cars, you'd think something as "proven" as fuel magnets and stuff like that would make their way into the production line if it worked.
So cut the crappy stuff out, and think for a while. It's all a placebo. " I paid good $$ for it and it definitely works, cause if it didn't i'm as good as a sucker"
https://www.sau.com.au/forums/topic/159841-use-of-hiclones/#findComment-2972738
Sorry if it was too blunt and harsh, its just that i've got wayyyyy too many friends who paid good $$ for this kinda stuff to try to improve fuel economy and get more power. And they swear by it, and it just gets a lil irritating sometimes. The best way to get better fuel economy out of your car is always your right foot, and of course your necessary maintenence, tyres and tyre pressure, etc.
https://www.sau.com.au/forums/topic/159841-use-of-hiclones/#findComment-2973020
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
