Just took my GTR out for abit of dragging fun 2night. Was pretty impressed at getting a 13.1 @ 106 mph for a basically stock 32 gtr with just a cat back exhaust and exedy button clutch. The factory spec is 13 flat out of factory right ?
Also something i found weird was i was just red lining 3rd gear as i crossed the finish line. That compared to my supra ( i was redlining 4th gear as i crossed the finish), just wasn't used to it. I guess that is becoz of diff gear ratio's ?
My 60' time of 1.943 is abit high right ?
Any tips on how i can lower that abit ?
Other than that i was pretty happy with it. The AWD sure is great for launches (even with street tires) compared to a rwd with street tyres aswell.
Any comments or advice is very welcome :ninja:
https://www.sau.com.au/forums/topic/159848-gtr-32-14-mile-time/
  • Replies 47
nice work, wat sort of mph were you doing in the supra and wat time
umm if i remember right it was 13.00 @ 111 mph
So it had a 12 in it but standard clutch and shitty street tyres restricted launches alot.
GTR should be able to manage a 12.9 easily.
Keep trying!
how should it be able to manage a 12.9 easily when they are 13 flat from factory? and i have very minimal mods. Also consider it is 16 odd years old so it wouldnt be running the factory times now days. :ninja: but ye u are right i should keep trying because practice makes perfect right :)
did u lower ur tyre pressure. and the 1.9 60 footer is a little high i think when mines a 2.0 and its a gtst
yeh i did let them down to about 20 psi in the rear. But i wasnt gettin much traction loss at all really. Yeh i have to perfect the launch and i reckon i could get the time down abit.
i have found
dont go below 20psi on street tyres (good for slicks) but with street tyres below 20psi you start to lose the bonus of letting them down (something to do with the fact they are steel belted) the best pressure is 22-25psi (depending on day)
also if you have aftermarket clutch you should be launching at about 6k for best launch (handbrake on let out clutch till just enguaging then just drop and release handbrake) , with a 4.5k launch you will be dropping of boost for short period (destroys your ET) i stuffed a launch once revs dropped to 2500 and did a 13.6
also with your trap speed of 106mph you should be running mid-high 12's
i have done a 12.7, with 60ft = 1.8 trap speed = 105mph
mods were turbo back zorst, pod filters (no shield) , 11psi boost, tune (car prob made 205rwkw) and full pressure tyres (36psi)
but it is simple as Practice makes Perfect ... play with revs on launch, dont wait till limiter to change gear (i change at 7200-7500) should be changing just after your peak power/torque
and most of all ... have fun ... but thats not hard when you own a skyline
hope that helps
Cheers
RellikZephyr
Edited by RellikZephyr
for launches in a GTRRRRR you need to launch em at about 6000RPM + then u will be amazed... ;)
But u gatta be carefull with ur diff and all that... my mate did a 12.1 in his 32gtr and he was dumping it at 7000rpm, and on stainless steel tyres.. :D and he broke his gearbox 2 days after... his gtr has a full exhaust and cusco soil overs...
Yep 5500+ I've found to be best with a gentle release of the clutch, got to try with a Jim's clutch soon.
Stainless steel tyres? They'd be a pain to keep clean and a solid ride :-)
When i went to Heathcote, my best time of the day on my stock GTR (R33) was when i changed gears earlier, i crossed the line in 4th gear. I shifted at about or just under 7K and got a 13.2 @ 106. I had a 1.9 60ft aswell, the track seemed really slick compared to the street and she was just spinning all fours, ended up launching at about 4800-5000rpm. On the street it does need 6K plus or else it will bog down (twin plate takes up all the slack instantly).
i found i got to much wheelspin doin limiter launches (strip not quite a grippy as road)
about 5800-6k is the best spot to launch mine i found (on Potenza GIII's and OS Giken twin plate clutch)
with that little bit less wheelspin she hooked up bit quicker
did limiter launch ran 12.88 did a 6k launch got 12.76
and i change gears earlier cause you can feel when she goes past her peak torque (mine approx 7500) and thats when i change
RellikZephyr
When my 32 GTR had 228rwKW it ran a 12.4 @ 181kmh. (112mph)
I'd be changing to 4th before the end of the qtr.
I'm not interested in destoying my car to shave a few tenths so stage my car at around 5500rpm, and feed the clutch out quickly, results in consistent 1.9 60fts
I went from a 340rwHP 2WD RB30ET Skyline previous and I must say launching a GTR is 110% easier and more consistant :P
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
