I can get a brand new set of gt2860r turbo's for my r33 gtr vspec for a good price!
Has anyone had any experience with these turbo's before???
What are they like??
It's for a street car so i need some response still???
Any thoughts would be handy!!
Thanks
https://www.sau.com.au/forums/topic/159854-would-these-turbos-be-ok/
yep just put some on my R32 GTR
feel great just a little bit lagger than stock R32 units but push really hard.
Only thing that didnt fit was the oil drain fitting on bottom of turbo so the bolt holes need to be slotted to fit.
Noone,
Fairly self explanatory, tis when you need it to fit, but cant be F'd or don't need to make a new bracket... so you drill / file out to fit
Scuze paintshop work
Are you sure that was all the issues? I had a mechanic describe a whole list of issues putting these on - of course I can't remember the specifics.
I see you're in canberra - did you do it yourself, or get some place to help you out?
Edited by cash0
Yer I just fitted them to my 32 as well. It's a big job but yes they do bolt straight up and the only modification is to slot the oil drian holes. It does seem alittle dodgy but but there's no presure in these lines so it's perfectly ok to slot the holes. I'm having other issues with mine at the moment though with "shuffle", mainly because I haven't got the necessary supporting mods yet and it's not tuned.
there are more "tricks" than "issues" when fitting them. Many green gtr mecahnics struggle with removing and fitting the turbos ie taking like 2 days to do the swaps....
Edited by URAS
Thanks
They are a direct bolt on....which type do you have..-7,-5,-10?????
Each are different.
Okay havn't had my turbos off YET so wasnt sure just thought drain holes would be threaded, slotting seemed like it could result in leaks I am assuming that isnt the case.
These sound like the go though little bit more lag than stock but capable of heaps more up top with the 2860 -7
and abit more lag than "-7's" with heaps more up top for the 2860 -5's
Just to clarify can I make a bracket change lines to avoid the need to slot the holes? Is there any point avoiding it ie. does it leak or anything if u do?
Edited by noone
its a common mod, if you cant master this simple task without disaster it would probaly pay to get some-one to install the turbos for you. trust me you should be fine.
thanks for your help as I stated havnt yet taken turbos off YET so am just more than anything wondering if these holes are threaded etc. think I can probly make a bracket OK or slot the damn holes "without disaster" I just assumed at first read these holes would be threaded for the oil return lines yet others have stated they elongated the holes was curious as i thought you would have to get a good seal so as to not have oil going everywhere guess not.
These sound like the go though little bit more lag than stock but capable of heaps more up top with the 2860 -5
and abit more lag than "-5's" with heaps more up top for the 2860 -7's
believe that
-7 is GTSS size
-5 is 2530 size
therefore you'd get more lag from a -5 than -7 but more top end for -5.
PS, byebyev8, big threads on these turbos if you search
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
