Just a quick question, if pineapples are fitted to the rear of an r33, will it upset the rear camber at all. I'm having lots of problems setting up camber and tracking and i'm looking for the best setup at the best price. Also I live in Ireland and the roads are full of holes and sheep and goats,
https://www.sau.com.au/forums/topic/159856-rear-camber/
I have got one set of rear camber bushings installed and set up. But i still have 1.26 degrees of negative camber and i'm wondering is it the pineapples that are causing the extreme camber. I have lowered the car only 40mm on springs.
https://www.sau.com.au/forums/topic/159856-rear-camber/#findComment-2970136
1.26 neg is nothing to worry about. if you are having trouble with the car wanting to steer itself all over the road, then i would be looking at toe settings.
Seems a bit better since i got it tracked on ssaturday. What sort of toe settings would be suitable for a road gtst. Also does the car have to be running to set the tracking, (i now have a hicas light coming on).
Thanks for all the help so far.
https://www.sau.com.au/forums/topic/159856-rear-camber/#findComment-2973506
Ah k, got ya. No the car does not have to be running when it's wheel aligned.
BUT I wouldn't be going to get a new alignment with faulty hicas. get all the suspension and steering working (inc hicas) properly before getting the alignment done.
https://www.sau.com.au/forums/topic/159856-rear-camber/#findComment-2977358
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
