Hi ppls,
I'm redoing my intercooler and will be buying a core (most likely from JJ) and then redo the piping myself.
I'll be running maybe a touch over 300rwkw on 18-20psi.
I'm looking at a cheapy intercooler thats 600x300x75 and runs 2.5" piping from JJ on Ebay.
There's another that is the same size 600x300 but is 100mm thick BUT runs 3" piping so I'd have to run a step down silicon connector as most of the JJ/Gktech kits do.
Is a 75mm thick cheapy intercooler sufficient for 500-550bhp or should I just grab the 100mm thick item?
I know of a few running the JJ/GkTech kits and they are pushing 300rwkw without problems BUT I believe its the 100mm thick core. Any one done those sort of power levels with the 75mm core?
I'm running a cheapy 75mm core for my 288rwkw. I think the 100mm will be a bit harder to mount behind the reo and keep stealth.
I've been thinking about the 100mm jj core with the better end tanks though as i think there will be some gain from the tanks if nothing else.
if you are after the absolute best then go for a tube and fin, 90mm core and minimize the pipe work if you canb
but i would only be doing that if you can afford it, have the right plenum setup and the compressor isnt way out of its efficiency zone
make sure the end takes are smooth, curved and taped and not boxey or squared off.
http://www.are.com.au/techtalk/intecoolersMR.htm
plently of info, covers turbo lag, pressure drop maps, cfm flow for 2, 2.5, 2.6 and 3 litre setups and various cores, pipes and methodology behind intercooling
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
