is there such a thing as a stand alone knock sensor/detector/adjuster. The ecu I have decided to go with doesnt have knock sensing and, despite the tuner reassuring me he can set it up just fine without I would feel better knowing it was being monitered.
https://www.sau.com.au/forums/topic/159884-knock-sensor/
