  • Replies 78
well porche has one nice mofo of an engine in its strainght 6 and so does BMW with their m3 straight 6 and so does nissan with the rb's and so does toyota with their 2jz....i can see some sort of trend here...
my bro's 85zx was a 3L v6 but could only make 160hp yet my old supra was a 3L straight 6 and made 200hp! and we all know there's nothing wrong with the power out of nissan engines!
holden has a ***ed up v6 as does the magna so i base all my opinions on the evidence...
Originally posted by Lozza150
If you want a real spin out..... try and find out how a "Rotary" engine works....
Yeah, that's a freaky kinda engine - what was that bloke thinking when he invented them :confused:
http://travel.howstuffworks.com//rotary-engine.htm
Originally posted by djvin
A couple of questions thats slightly off topic,
Has any car company made a V4? And would there be any savings in making one?
Yep SAAB made a V4 at the end of the 95/96 model cycle, and Lancia have been making them for decades. What a sweet little donk that is. :uh-huh:
Originally posted by WazR32GTSt
well porche has one nice mofo of an engine in its strainght 6 ...
umm that'd be boxer 6 :(
Hehehe Lozza150, took me a while, but I finally got it!
woz the 'a real spin out' an intended pun?
Coz thats really quite nifty...
real spin out - rotary engines...
lol, boy am I slow.... n also amusing myself at the smallest things...
ford made a V4 back in the 70's for the capri, granada and transit and it was a piece of crap of a motor.
porsche never ever made an inline six. they were either a flat six, inline four, flat four or V8. :P
the Wankel roatary engine was originally a design for a water pump. ;)
Hey red900ss man, ure Avatar is fully sickening man...
That a turbine from a truck or something, looks HUGE!
lol,
Guess thats bolted on to ur Skyline then?
yer it's off a Ship. It's mounted in a box trailer :uh-huh:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
