Hi guys
I have moved up from nsw recently and have brought me a r33. just stock but still fun.
have big plans ( as most skyline drivers ) just getting the drivetrain right first.
I am currently working for a company called capral aluminium, plate sheet angle bar sell all shorts.
so if anyone needs aluminium or some advice or just wants to chat come see me.
Jacob
capral trade centre
67 parramatta rd
slacks creek 4127
ph: 3209 1222
Fax: 3208 8729
https://www.sau.com.au/forums/topic/159908-new-in-town/
na man i only sell the shit but try
the goodwin & sons or csf specialist welders and mention my name
OH! so you reply to Bunta's question and not mine?!?!?!
I see how it is..... ;)
:D
Hano------> :( <--------Tin Man Costume
p.s. a thousand welcomes to you to Triptych
Edited by LIL34
https://www.sau.com.au/forums/topic/159908-new-in-town/#findComment-2982673
:D
Dont piss the other anna off new-type-person..
She will deck ya.. or die trying.. and you dont want that on your immortal soul do you?
but hai2u.. hope to see you around the scene :(
https://www.sau.com.au/forums/topic/159908-new-in-town/#findComment-2982688
I see how it is..... :rofl:
:rofl:
:rofl:
Hano------> :rofl: <--------Tin Man Costume
sorry darl
and yere i could try lol.
just need your dimensions
waist =
height=
bust=
arm lenght =
leg lenght=
bust=
oh shoot already said that, lol
:D
https://www.sau.com.au/forums/topic/159908-new-in-town/#findComment-2987360
Hi guys
Jacob
capral trade centre
67 parramatta rd
slacks creek 4127
ph: 3209 1222
Fax: 3208 8729
Welcome mate :P I'm sure there'd be a few guys on here interested in popping round to see you about work! Good to know of someone else that DOESN'T work in IT :)
tues night dinners ay yere sounds alright keep me informed
They are posted every week, without fail, in the events section :rofl:
That is because I am gun....you are not
I'm sorry, who are you? You are not gun.
I am the leader. You know... 'following the leader'? that was me... & 'da na na na na LEADER!'... that was ALSO me. :D
:sorcerer:
https://www.sau.com.au/forums/topic/159908-new-in-town/#findComment-2990935
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
