Ok so I have gone out and got myself an O2 XDAII Mini mobile phone / pda thing and I can not for the life of me get the damn MMS working.
Virgin will only sms me the setting not tell me over the phone. SMSing me the settings will not work they have not sold these phones in the past.
Phone calls and Text SMS's work fine! No problems at all.
Operating system is Windows Mobile 2003 Second Edition ( Pocket PC )
I have searched the net and have found many people with similar problems.
Help me!
I've got the XDA2 just a bigger version of yours, but am with optus.
Quick google around gave me this link for you:
http://www.mtekk.com.au/Forums/tabid/56/po...ic/Default.aspx
Should be very similar for you, basically all you need is a GPRS connection for the MMS program to connect to, with your access point name as VirginMMS
Then in your MMS program, create a new server with the settings:
http://mms.virginvibe.com.au:8002/
202.139.083.152
port 8070
And that should work. You can send yourself a test mms and you should get it to make sure its working.
When you go to START --> SETTINGS --> CONNECTIONS
Then you have Connections or GPRS Settings
Under GPRS on the Authentication Tab what do you have your phone set as? Either PAP authentication or CHAP authentication? and under the other Tab do you use class 8 or Class 10 settings?
Back to the
If I click on -> manage existing connections.
It shows me 3 tick cicrles
NAME NUMBER
Auto pick
SBS PPP
VirginMMS VirginMMS
I have no spot where I can enter a http address at all if I click edit on the VirginMMS one.
It asks for a Name for the Connection ( I call it VirginMMS or workmutharflarkerwork ) depending on my mood.
It also asks me to select a modem.. weird.. I select --> Cellular Line (GPRS) then NEXT
It now asks for the Access Point name.. I Type in VirginMMS the NEXT
USer Name:
Password:
Domain:
I enter nothing
ADVANCED:
use server assigned IP address. ( I select this option )
Can enter in Specific IP address if I want.. not selected.
Use Slip?? Not selected
Use Software compression?? not selected
Use IP header compression?? not selected
Dont make it friggin easy do they.
>_<
Just use generic optus GPRS Settings. they will work.
OH your account needs GPRS/Internet Data setup too
P.S. I just got my o2 Graphite 3g windows mobile 5.0 phone, dam vodafone 3g, cant make video calls, but can recieve them. "Oh update your software" Its been on the market for 2 weeks THERE IS NO NEW SOFTWARE.
Douchebags. Ohwell, vodafone will shut up shop soon just watch!
Ahhh
stuffed it
I reset all the settings some how.
Friggin crap.
I can build a damn windows Server 2003 System and Install every operating system under the sun, encode in C++, VB, pascal, HTML yet I cant get my damn phone working..
What kinda world is this I ask you..
hehe
yep awesome phone can even play divx/ xvid videos on it.
Will try default optus settings, where do I find this option?
Damn thing has so many options..
