  • Replies 57
Posted Images
stock ecu, stock everything else lol (bs)
added the air fuel ratio which is basically what i remember seeing on the screen for run no.2, although this is the print of run no.3. uses the same scale as the boost, so you get the idea, it went rich as the high 9's at the top end.
this is where the powerfc will come into it. i guess it means my pump and injectors will handle a tiny bit more too if they can still run that rich at 6000rpm. even the peak at the end was 10:1.
:wave:
yeah, buster is top of their 6 cyl forced induction list.. and 2nd, 3rd... lol they ahd a few big power printouts on their wall.
apparently adam is the guy to get down there, but he is jetsetting a bit so you have to ring ahead. They were happy to install fuel pumps, injectors and ecus... but werent really a mechanics place. JEM=Just Engine Mangement after all.
Nice photos there! Only one sexy silver s2 lol....... Who owned RUSSIA? Can't belive i beat him haha......Now i just need some mods and i'm away....QRIO5E, i willl be going to livo exhaust soon, so i'll let ya know we'll cruise down there.....
Haha you only beat him by like 2kw's or something but I'm positive he can drive better..
Not to mention Kirill's car also ping's so there is something wrong with it..
russia only did two runs i think, it was pinging badly. his was stockish too. very nice looking kit tho, especially after you washed it in my front yard you water theif... lol
bit of drift damage too.. looked awesome. chunky ass tyres.. i rememner all.
thanks dude... was nice to meet you.... :happy: come around, still some of my water *beer that is* if you want one day .... LOL
beat me by only 0.8kw... that's huge number... :happy: was MR33 on stocks rims? u know if i put stock on i will make more power on that thing... :D
PS: damm that ping thing... need help to fix it up anyone?
yeah you need some management unfortunately, but try resetting it first. just take off the negative battery and leave it overnight or press the brake a few times to get all the power out of the ecu., then turn on and let your car start from the nissan maps again.
or get someone with consult etc. to reset it. Some say it doesn't do anything, but i used to reset mine after each major mod and got a ridiculous power figure off the stock ecu, so i dunno. may aswell.
power fc is in now and car feels so much better, especially between about 2500-3500rpm.. thanks brad you are the champ *rocky theme music*
Id be knocking the timing back via the CAS to prevent it from detonating if thats the case. With a stock ECU fitted and the base timing correct it should not be pinging at all.
PM me if you need to know how to knock the timing back and check it.
Adam is a top bloke id agree. QRIo5E if people want to use Adam im sure they can call him and organise the work themselves instead of using you as a middle man. Im sure adam would rather run HIS business like that as well??
Recommendations are all very well but people can organise their own work.
Jeff glad to here your happy with the car. It does have a really nice midrange, I spent alot of time with that section of the tune and it really does show when driving the car on the street.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
