Can confirm the Quick Edit function has made a return.
Can confirm the "new messages" link is no longer showing -1 etc.
Can view profiles, can use either Fast Reply or Add Reply.
Cannot confirm the return of user tags eg Donator, Qld Club Member, Qld Exec Member. Have noticed WA Club Member, Super Moderator, Moderator, NSW Club Member, Vic Club Member, Vic Exec Member tags have been returned but there appears to be inconsistencies with their applications (meaning not all members have had all their user tags returned).
I am using FF 2.0.0.2
Thanking you,
Karen
  • Replies 108
Posted Images
Thanking you,
Karen
Same here all back except my NSW members bar & Donation bar. Can view profiles etc just not the link above everyones avatar...
Also will the trader ratings be shown as before when someone posts ??
yikes.. its a long process but i am getting through the list.
Trader Ratings can still be accessed by clicking the link up the top ^^ But the links in the side bar and profile will be back shortly.
prank, atm when i click the trader rating link up the top I can only see the top 15 guys. if I try a search I get page not found. I can't leave any feedback atm either. just letting you know :glare: this is in IE btw, but from memory it's the same in firefox at home.
When im viewing this thread, above the SAU Banner... i can see multi user tags... seems the code was inserted wrongly i think :D
i have the above problem x10. its not just user tags its random code, sigs, avatars etc. all before the sau banner. below that the thread continues as normal but theres so much junk i had to scroll down b4 i knew there was the normal stuff. only happened in bout 7/20 or so sau pages i loaded and is easily fixed by refreshing.
also sometimes i get the window as shown in the second pic. again its fixed by refreshing
Ye, thats cause Christian is playing with the coding etc.
It will subside in time :D
ps. drop your sig back down a bit please :laugh:
Those of you getting strange issues when clicking Options or Quote, can you tell me what browser you're using.
Yeah quoting is working fine... Thanks...
I'm missing my moderator bar and my mod access doesnt seem to be working for my section .... :laugh:
Nice one Slim... Thubms up for effort... :D
It remembers me until I reboot the PC
Alot like most Qlder's Cyrus... :glare:
Yeah I have no access to the mod section. Can someone plz pm me the password. Ta...
Also I notice that no one has multiple tags as yet, ie. Super Moderator/Moderator/donator/qld club member...
Cheers Col
PS. Top effor to Christian, I know this has taken a stack of your time...
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
