## Is This A Maf Fault ? ##
I've spent the whole weekend trying to sort out the idleing problem with my gtst. I've gone thru the whole cleaning thing with the throttle body, ICV and even removed all the plugs, cleaned re-gapped and taped up and cleaned the coilpacks.
I've reset the ECU that many times i've stopped counting!
I've taken out the new 255lph fuel pump and put the original back in and cleaned out the fuel filter.
AND YET IT STILL IDLES LIKE A C**T!!!!!:sorry:
So as a matter of course i removed the ind kit cone and then the MAF from the air intake, and low an behold it idles along great, not lumpy at all, it sounds lovely, UNTIL i plug the connection back on to the MAF then the engine dies!!!
Without the MAF connected the engine idles great but as suspected as soon as throttle is applied the whole thing becomes unbalanced and not very nice.,
Now i've tried cleaning the MAF sensors with switch cleaner but that hasn't made any difference at all.
Is this a fault with the MAF or is it something else that is taking the signal from the MAF when it is plugged in?
If it is the MAF, where can i get one and how much can i expect to pay?
your advice and suggestions please ppl
thanks
Ricky
Edited by ricky-tk
Yes it is A MAF Problem. Replace the unit. There are plenty options. 300zx, Q45, you may have to rewire and may need software like a Pwr FC. I have a Pwr FC with a Q45 unit. Works Great.
FX
just find someone in your local area with an r33 and borrow their afm for a few minutes
then if that works you just need to source a 2nd hand 33 afm, should be no more than $100
 Share
    • Thank you for the links. I’m going to go with the 6pin plug you used. next step is rust treating re painting dash support bar and steering column then the 6pin cradle plug when it arrives in the mail.
    • I don't how much the car makes a difference or whether it is just a question of gearbox and clutch. On mine it's fine. Pull type Nismo coppermix twin (standard, not competition) on the 5 speed in my Stagea. OEM slave cylinder. Bite point is a few cm off the very bottom of the pedal. Clutch pedal all the way down to put in gear, and when heading off at the lights, there's a tiny bit of nothing and then it starts biting. And fully engaged before the pedal is all the way released. There's a bit of play at the top where the pedal does nothing anymore. Are you in Australia @ck_chino? If you are set on using a Nismo slave cylinder I have one new-in-box at home. Ordered it together with the clutch but didn't get it fitted. We can work something out if you want it
    • I am using a pull nismo coppermix twin in an r34 getrag box, had both the standard slave and  then the nismo one. Adjusted pedal to get bite point how I wanted , it is on the higher side, but would fully disengage past half way down.  I also read that the nismo slave won't work but I had no issues with the stroke, might become one later as clutch wears but 2+ years of happy motoring so far.  Take the above as one input only, specially as my setup is a bit unique in that I am using an S15 clutch master , cefiro clutch pedal, custom braided clutch line. Lots of variables at play.
    • Oh for sure, I'm just recounting my thoughts 😎 I'm not what you've got there to fuzt with.... likely my first idea was on the money -- rebuild or replace connectors. You can get a lot of connector stuff here  -> https://www.rapidcables.com.au/ Didn't look in the boot of mine, because I replaced these when I renewed the pump (plastic of connectors had gone brittle) edit: what I used... https://www.efihardware.com/products/2120/Deutsch-DTM-Connector-Kit-6-Pin ...cheaper... https://www.ebay.com.au/itm/364900039138
    • In no way was i suggesting it’s your fault mate. The trailer cable has a plug that I removed. I will have a closer look, but I did remove the trailer wiring cable with the tow ball as I don’t need it on my silo. i have replaced the fuel pump already there’s no need to remove the cradle again I can see the wire colours from it in.
